Race build YB 2w/d com/ratio help
Pete here racing my mk1 escort CTCRC boss.
Chasing info for the right compression build.
Build spec 205 block @ 92mm bore. 2046cc
Pistons valve pocket Wiseco 103M92AP + above block deck by 0.0200"
Piston Bowl 20.2cc
Stroke 76.95mm
In stock Gasket WRC 1.3mm new,and two used once two Cometic 92.5mm/0.080"Thick.
Need to know if someone can work out to get a 8to1 compression ratio for me.
Hands up Not measured head height,but its well knife edge opened up ported.
What safely can i do,Cheers Pete
Piston Bowl 20.2cc
Stroke 76.95mm
bagginsRSturbo
22
Nov 20, 2012 08:46 PM
coachworz
Jun 13, 2008 05:31 PM
