Supra diff weir kits
Old Apr 3, 2018 | 11:39 AM
timsrs's Avatar
timsrs
Default Supra diff weir kits
When these are fitted how noisy are they
When cornering slowly etc
What noise do they make
Can they be set at different rates
My cars a road car but going to be running good power
Hence the supra diff as I want it reliable but don’t want a road car that going to sound terrible
Regards
Old Apr 3, 2018 | 11:49 AM
nixon_2wd's Avatar
nixon_2wd
I haven't run mine yet so cannot comment on the noiselevel, but the clutch packs are set up by shims so you can adjust the preload / lock up torque.
They come in two different configurations, I got the "fast road" option, with the additional spring. The "full race" version replace the spring entirely with a harder, washer type concave spring setup, making it lock up faster.
Old Apr 3, 2018 | 01:34 PM
Caddyshack's Avatar
Caddyshack
Mine got quieter after 300 miles. I do not notice much noise but have had the odd clonk when turning the car around etc..
Old Apr 3, 2018 | 07:51 PM
timsrs's Avatar
timsrs
Thanks
Mark at MK said it’s a worth while upgrade
I’ve read they do quieten down after some use
Do you know what torque you’re is set to
Tim
Old Apr 3, 2018 | 08:31 PM
Caddyshack's Avatar
Caddyshack
I got Bara motorsport to do mine, I don’t know what he specced it at.
nixon_2wd's Avatar
nixon_2wd
It depends how worn the clutch packs are what rating you will be able to achieve. I had to stack all the shims in there, and that got me to 85Nm (mine is quite worn). Max is about 100Nm on the road race kit.
I will be upgrading to a Cusco RS LSD in the future if Im not happy with the weir kit. Its a fully adjustable 1,5 to 2 way, adjustable torque LSD.
Old Apr 3, 2018 | 09:10 PM
Caddyshack's Avatar
Caddyshack
85nm does ring a bell now you say it
Old Apr 4, 2018 | 04:18 PM
turbotrev's Avatar
turbotrev
Mine is a little bit clunky but by no means ‘noisy’, it’s no worse cornering etc.
Speak to bara about your set up and he will set it up for you accordingly
Cheers Paul
Old Apr 4, 2018 | 04:44 PM
Caddyshack's Avatar
Caddyshack
I think a good one on good bearings etc is not bad at all, I didn’t really notice mine.
My old 325i bmw e30 and e30 m3 were both worse on standard but worn lsd’s.
BRAMMER
42
Sep 10, 2017 05:21 PM
ginner
20
Oct 12, 2012 09:46 PM
R5COS
Ford Escort RS Cosworth
Jan 21, 2008 09:15 AM
