Ford Focus Range This Section Contains All The Ford Focus Model Specific Forums.
Brake disc not clearing
Old Apr 1, 2018 | 08:31 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
Default Brake disc not clearing
hi has anyone had this issue? New pads and st170 discs with Mondeo mk3 caliper Carrier oh 170 hubs
the outer 50% of disc clears during use the inner stays rusted from rain etc
onky in drivers side
sliders good and greased
thinking sticking caliper? Cheers for help
Old Apr 1, 2018 | 08:33 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
Old Apr 2, 2018 | 10:31 AM
Caddyshack's Avatar
Caddyshack
Looks like something is sticking or is not straight on the car
Old Apr 2, 2018 | 01:48 PM
focusv8's Avatar
focusv8
If the caliper isn't sticking, it's something to do with that shocking dice on the valve..
Is the caliper carrier on square?
Old Apr 2, 2018 | 02:03 PM
costina's Avatar
costina
Live long and prosper!!
Caliper is not square to hub or caliper is not central to disc.
Old Apr 2, 2018 | 02:04 PM
costina's Avatar
costina
Or just a shit set of pads
Old Apr 2, 2018 | 02:35 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
i suppose you might be right considering the local kids haven’t even nicked them lmao
im certain they are but I’ve picked up another caliper and carrier for a tenner should be here Wednesday to rule that out
Old Apr 2, 2018 | 03:03 PM
focusv8's Avatar
focusv8
Todays kids wouldn't want those dice unless they had electronics in them and flashed,,
No, don't tell me,,,
Old Apr 2, 2018 | 07:44 PM
STeve's Avatar
Super Moderator
better off with 170 calipers anyway as they give more clearance for the rim but as chaps have mentioned those carriers must be mounted on the piss or something
Old Apr 2, 2018 | 08:12 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
Mondeos have bigger piston and pad surface and lose the shitty wire clip
Old Apr 3, 2018 | 06:42 AM
STeve's Avatar
Super Moderator
if they work lol in your case your losing 50% so no gain at all
Old Apr 3, 2018 | 02:19 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
would a slightly twisted/kinked rubber brake hose cause it DOH
Old Apr 3, 2018 | 02:41 PM
Caddyshack's Avatar
Caddyshack
I wouldnt have thought so unless it is making the pad retract unevenly / or clamp unevenly....sounds like the braking system might need a good coat of looking at.
Old Apr 3, 2018 | 02:46 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
i have already sorted the hose out - didnt notice it wasnt quite right lol but ive yet to test drive
Old Apr 3, 2018 | 03:25 PM
STeve's Avatar
Super Moderator
wear like that on the disc has nothing to do with hoses its the carrier bracket not being true so caliper is on the piss unless your piston is split in half
Old Apr 3, 2018 | 04:27 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
Ok mate cheers worth asking anyway
caliper/Carrier replacement being delivered tomorrow so I will thoroughly wirebrush everything and fingers crossed it’s sorted lol
Old Apr 3, 2018 | 04:37 PM
costina's Avatar
costina
Looking at your pic I would guess that the rear of the disc is clean on the opposite to the front.
so the inner would be clean and the outer rusty.
Old Apr 3, 2018 | 05:04 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
the inside of the same disc is perfect (piston side) its just the face in the picture that's weird
Old Apr 5, 2018 | 02:34 PM
Swearwolf's Avatar
Swearwolf
mad mechanic
for anyone interested i changed the caliper and carrier this morning, the brakes instantly seem sharper and i think the rust area has faded slightly, ill let them re-bed and hopefully job done
the old caliper i could swear the piston was at an angle...
boy-racer-1
Jul 31, 2011 12:42 AM
Oranoco
37
Nov 30, 2010 07:58 PM
Computers, Consoles and I.T.
Jul 14, 2006 02:47 PM
Big G
Jun 2, 2006 05:25 PM
EIL132
Aug 3, 2005 04:42 PM
