Co Screw
Old Mar 29, 2018 | 04:14 PM
2Litre's Avatar
2Litre
Default Co Screw
Hi all-
I know that the CO screw is a global modifier and adds or subtracts a percentage to or from the fuel table. Is this percentage equal at idle and at WOT? i.e. - What I mean is if I remove 1 unit say from 14afr at idle to 13afr at idle with this equally remove say 12afr at wot to 11afr?
Thanks for any info.
Best.
Tim.
Old Mar 29, 2018 | 04:32 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
No it actually changes the map sensor input voltage, it is best to set the CO pot to Zero pot position turn the co pot 5 turns in either direction then exactly two turns back.
Old Mar 29, 2018 | 04:46 PM
2Litre's Avatar
2Litre
Thanks- interesting, that said does this map sensor voltage input change effect fueling equally at idle and at wot?
Best.
Tim.
Old Mar 29, 2018 | 04:57 PM
2Litre's Avatar
2Litre
Another interesting question would be to ask- If I increased my fuel pressure from 3.5bar at 1 atmosphere to 4bar and leaned the engine back out to the 3.5bar value at idle using the co screw would the wot afr be the same as they were at 3.5bar?
Thanks.
Tim
Old Mar 29, 2018 | 05:17 PM
Turbosystems
Super Moderator
Best.
Tim.
No
Set the static fuel pressure to 3.8 bar and zero the co pot and asses the fuel curve you now have, do not try and tune your fueling via the co pot. I also suggest you check the intake system for air leaks either via the smoke method or pressure method. Check your fuel pressure rises directly proportional to boost
Old Mar 29, 2018 | 05:46 PM
2Litre's Avatar
2Litre
Thanks - Yes I understand the increase of fuel pressure will richen the fuel curve had a chip set-up running 4 bar to get the fuel required on 803's the lower end of the map was leaned out by the author of the chip.
Surely a wideband will let you know the effects adjusting the co has?
Thanks
Tim
Old Mar 29, 2018 | 05:55 PM
Turbosystems
Super Moderator
The pressure sensor input signal is used by other tables in the ecu such as idle strategy and transient fuel correction
There is a lot of useful information for you to read and research here http://www.bigturbo.co.uk/ click on Maps
Old Mar 29, 2018 | 06:11 PM
2Litre's Avatar
2Litre
Thanks , will have a look.
Tim.
Old Mar 29, 2018 | 06:50 PM
2Litre's Avatar
2Litre
Interesting read - why have a co pot at all if its potential must be zero for other maps/strategies to work?
Thanks.
Tim
darren.cudd
Aug 2, 2004 08:41 PM
kevsrs
Jul 28, 2004 10:00 PM
XRTypeRS
Jun 28, 2004 01:49 PM
kenny
Jun 4, 2004 05:10 PM
