Quick question. Original colour of the cvh engine block
Old Mar 27, 2018 | 10:06 PM
ger80's Avatar
ger80
Default Quick question. Original colour of the cvh engine block
I'm restoring a 1990 Fiesta Xr2i. I've media blasted almost everything underneath the car, and also the engine. I think the engine block was originally black, but can't be sure. No colour is left on it. I assume the sump is also black. Am I right? If it is, is it matt or gloss or satin? If I'm wrong, can someone tell me what colour it is.
Thanks
Old Mar 29, 2018 | 09:03 PM
Doodah's Avatar
Doodah
er
Gloss black sump
(new) Iron-coloured block?!
Old Mar 29, 2018 | 10:33 PM
ger80's Avatar
ger80
Iron coloured, as in a brown?
Old Mar 30, 2018 | 12:25 AM
Doodah's Avatar
Doodah
Whatever colour the bare metal is - I'm not sure if the blocks had some kind of minimal rust protection but they def weren't painted. Just wire brush/ wool & dust off thoroughly and you'll be as close as you can get. Shouldn't rust anyway on the outside in normal use unless there's a leak somewhere
Don't think it'd hurt to paint it though while you have the chance, even on a resto
Old Mar 30, 2018 | 01:01 PM
martysmartie's Avatar
martysmartie
I believe it would be black.
Martin
Old Mar 30, 2018 | 03:10 PM
Doodah's Avatar
Doodah
Silver?
Old Mar 30, 2018 | 09:59 PM
Doodah's Avatar
Doodah
Ok I'm prob talking crap
Old Apr 3, 2018 | 04:56 PM
iansoutham's Avatar
iansoutham
OCD Victim
They had a black transit primer from factory just to make them look a little nicer nd to help prevent the looking rusty during warranty really.
On some, you will see the coating flaking off near the edges.
i would go with a simple etch primer to start and then black base with a satin lacquer to finish for longevity.
Old Apr 3, 2018 | 10:10 PM
ger80's Avatar
ger80
Thanks for the replies guys. I have blasted the block clean, and noticed that rust had started to appear after a day or so. I just painted it with a straight to metal black satin paint, and it looks well. Didn't really think about a lacquer actually. Good idea.
turbopaultje
82
Feb 9, 2026 08:08 PM
john_3.0s
Nov 10, 2015 08:23 PM
New Shell Dude
Sep 14, 2013 12:27 PM
Terry Tibbs
Sep 20, 2007 06:20 PM
Cawood
Apr 29, 2006 05:05 PM
