Radio quiet after battery change
2003 mondeo 2.0 TDCI. Ive changed the battery and the radio is super quiet. Ive tested the speakers and they all work using to 3&6 buttons to test and they work perfect on the test.
Ive inputted the correct code and the radio is finding channels and playing CDs doing what its suppose to do exept its mega quiet.
The balance, fade, treble bass etc... are all set right aswell
any ideas?
any ideas?
Is there an amp in the car?
Have you checked the earth is really clean on the battery? I wonder if there is a live that has been missed off the battery for something like perm live or amp for an aftermarket stereo or amp.
Ford radio's have a avc function I think it's called.
It turns the volume up as the speed increases.
Check that function also your bass and treble might have been maxed out hence higher volume this goes to 0 when battery is disconnected.
hope that helps you.
wilcox
Apr 5, 2019 08:22 PM
Henry Grant
Ford Fiesta
Jan 28, 2016 09:30 PM
maxiboy1
Fiesta's Other !
Jun 27, 2011 02:41 PM
Oranoco
Jan 12, 2010 08:51 PM
