Fiesta 1600 CVH
Old Mar 21, 2018 | 03:00 PM
steveo135's Avatar
steveo135
Default Fiesta 1600 CVH
Hi,
I have a Fiesta 1600 cvh on weber carb. The car has a really strong smell of fuel. No leaks present. Had it on the analyser today 2400+ HC can not get it to drop. Probably a loaded question but anything I can do before I go down the route of Zetec 1.8.
Thanks in advance
Steve
Old Mar 21, 2018 | 04:12 PM
xr2mk2turbo's Avatar
xr2mk2turbo
I'm assuming it's smelling fuel from the exhaust,could be it has the wrong jet, not set up properly and running rich, Or try another carb, if not sell it on. Service kits are cheap.
Unless I'm missing something like timing out it can only be in my mind carb related, but I'm no expert
At this stage it would be easier and cheaper to find the problem rather than going down the conversion route, they are never straight forward and will cost more than you think, plus insurance.
Not that I'm against conversions as I ran an escort turbo engine in mine and it was a hoot!
Jae
Old Mar 22, 2018 | 09:38 PM
studabear's Avatar
studabear
The hydro carbons are seriously high, that's a lot of un burnt fuel.
Is it misfiring?
Is the choke manual or auto and is it functioning correctly.
Is the car running a distributor and is the timing set correctly both valve and ignition?
TobyBrindley#12
Sep 27, 2012 09:15 PM
Tony Turbo
2460
Jan 30, 2012 07:34 PM
street
Apr 17, 2006 04:03 PM
Shows & Track Days
Dec 27, 2003 07:04 PM
Dec 13, 2003 01:02 AM
