Garage / Workshop & Tools Section. Given working on your pride and joy is often one of the reasons cited for owning a Ford, post all your garage and tool collection pictures and questions in here.
Focus RS mk1 MTX75 gearbox mod - help required
Old Mar 13, 2018 | 06:10 PM
paulusa's Avatar
paulusa
Default Focus RS mk1 MTX75 gearbox mod - help required
Hi, I have a 2003 Focus RS Mk1 which I race and I am upgrading my MTX75 gearbox to fit a Quaife close ratio straight cut dog gear set. While I am doing this I am gong to fit a transmission oil cooler and pump, has anyone done this before? I am okay on how to setup but need your help on where the best location is for the pump feed and return pipes should be located on the bell housing - I am planning to drill and weld in -8 bosses, the feed pipe I am planning to put on top above differential location (under the gearbox mount) and the return pipe has to be under the oil level (as near to bottom of bell housing as possible) - this is my problem, I cannot use the fill location screw hole as it is not below the oil level and I can't locate to close to an existing hole location without the risk of stressing an area.
if anyone has done can you please send me some pictures of boss locations or if they know details of someone who's tcould help me it would be very much appreciated.
Thanks for taking time to read post
pani_k
30
Sep 19, 2021 07:17 AM
superbikerider1
Dec 30, 2012 09:53 PM
Big Man
Nov 6, 2006 06:22 PM
gavintwopies
Oct 27, 2005 08:05 PM
BillyCabrio
Oct 6, 2004 01:09 PM
