Fuel rail adapters
Old Mar 6, 2018 | 08:27 PM
tosh's Avatar
tosh
Default Fuel rail adapters
Does anyone know where I could get something similar to these? Will only need one of them so I can fit the 2wd fuel rail to the 4x4 plenum.
Old Mar 7, 2018 | 10:19 AM
Caddyshack's Avatar
Caddyshack
I would have thought you could make them quite easily by tapping a bit of bar and weld it to a flat bit of metal and then drill it to suit. If you do a technical drawing of the measurements most machine shops or fabricators could knock one up for you.
The only problem I can see if that the injectors need to sit nice and tight to avoid any leaks on the seals
Why not just fit a 4x4 fuel rail? Mark Walker at MK has a 4x4 one that he can sell you as he has my old one and he can also sell you a billet one
Old Mar 7, 2018 | 07:08 PM
tosh's Avatar
tosh
I’ve sorted something now mate cheers.
TIFF
23
May 8, 2012 06:48 PM
damien roe
Aug 14, 2011 09:08 PM
graham jamieson
Aug 6, 2010 07:24 PM
zetec69
Apr 10, 2007 09:29 PM
ASHCOSSIE
Apr 16, 2005 12:49 PM
