Mk4 Mondeo 2.0 tdci fault
Old Mar 2, 2018 | 06:06 AM
The Crocodile Hunter's Avatar
Default Mk4 Mondeo 2.0 tdci fault
Our Mondeo had picked up an intermittent fault and is showing code p02e1 diesel intake air flow control performance. It mentions that the actuator is stuck open?
At light throttle the car sometimes goes a bit juddery
Anyone seen this before?
It's not generally that bad and if it does happen opening the throttle more clears it. It seems only happen shortly after setting off too
Old Mar 2, 2018 | 08:24 AM
Opps, just noticed I put this in the wrong section!
Could a mod please move it to general car discussion?
Thanks
Old Mar 2, 2018 | 08:29 AM
I've just copied it across so this can just be deleted
Thanks
21
Aug 18, 2016 12:41 PM
morgy motor
Jan 21, 2010 04:15 PM
pingpong
Jan 8, 2010 11:06 AM
madfifer
Feb 6, 2009 09:04 PM
JayKay
Feb 6, 2009 06:38 PM
