High power application with MTX75 - Clutch
Old Feb 28, 2018 | 11:49 AM
PhilRob1's Avatar
PhilRob1
Default High power application with MTX75 - Clutch
Hi all,
I have a Noble M12GTO3 that uses the MTX75 gearbox
I am looking for a clutch/flywheel/pressure plate application that is suitable for comfortable running at 500bhp/400lbFt of torque.
Does anyone have any recommendations?
Thanks
Phil
Old Feb 28, 2018 | 12:41 PM
Adam-M's Avatar
Adam-M
http://mattlewismotorsportonline.com...ate-2559-p.asp
Old Feb 28, 2018 | 02:35 PM
bassboy's Avatar
bassboy
MTX75? Front wheel drive application right?
I used a Sachs uprated clutch in my old Focus RS which was 430hp...handled the power with no issues and was a damn sight better than my 6 paddle AP Racing clutch I had in there previously!
Old Feb 28, 2018 | 03:10 PM
Caddyshack's Avatar
Caddyshack
I expect Reyland Motorsport may also be able to help
Old Feb 28, 2018 | 04:46 PM
Adam-M's Avatar
Adam-M
Sorry read it wrong pmsl thought it says mt75
Old Feb 28, 2018 | 07:04 PM
big_wasa's Avatar
big_wasa
Ttv do a very nice billet fly for the 3.0 and helix do all sorts of clutch to match.
Old Feb 28, 2018 | 10:51 PM
PhilRob1's Avatar
PhilRob1
Hi all
Many thanks indeed for the reply - yes it is the RWD transverse application of the MTX75. The TTV Racing Flywheel, with the Helix Clutch and pressure plate looks to be the best option to support my intended output - whilst should retain fairly civilised engagement characteristics.
Old Mar 1, 2018 | 07:23 AM
dojj's Avatar
dojj
Resident Wrestling Legend
from what i understand the mtx75 is the same as the mt75 box, just turned sideways so you could go along the route of the cosworth clutch kit depending on the original stuff that's fitted
they used a bigger clutch than the normal set up, 241mm as opposed to the 220mm versions but they still used the same size bellhousings
unless they've changed them on the mondeo application, in which case the st version would do the trick
Old Mar 1, 2018 | 09:05 AM
PhilRob1's Avatar
PhilRob1
THanks for the advice on the Cosworth kit. Ill take a look.
The clutch as standard is an AP Racing item and it may or may not use a slightly lightened flywheel, but I can confirm the Fidanza lightweight flywheel P/N is 186251
superbikerider1
Dec 30, 2012 09:53 PM
leecavturbo
309
Oct 12, 2006 02:03 PM
Fudgey
Jul 27, 2004 12:05 PM
All4it
Jul 24, 2004 09:04 AM
