Fuel lines and fittings
Old Feb 18, 2018 | 06:49 AM
timsrs's Avatar
timsrs
Default Fuel lines and fittings
What are people using to run fuel lines down there cars
I’m going to be running 044 fuel pump
I’ve thought about running 6mm copper fuel lines down most of the car
Similar to standard but was looking at braided with fittings for the rest
What have you used for the fuel tank to pump as the tank is s push fitting and how to join the braided to the copper lines
Thanks
Old Feb 18, 2018 | 07:26 AM
Caddyshack's Avatar
Caddyshack
I use speed flow. Faye runs it and is ex drag racer. She can make them up for you if you prefer.
Old Feb 18, 2018 | 07:56 AM
timsrs's Avatar
timsrs
They look just what I’m looking for
My concern is the tank fitting is push on
I know this is supplying the pump so pressure will not be too high
Old Feb 18, 2018 | 07:58 AM
Caddyshack's Avatar
Caddyshack
Yeah, she did me a push on end and then dash fitting other end. Just give her a buzz and email some pics and she will sort it out for you.
Old Feb 18, 2018 | 08:08 AM
timsrs's Avatar
timsrs
Thanks.....I’ll give her a call
Old Feb 18, 2018 | 01:00 PM
cossie51's Avatar
cossie51
I've used aeroquip AN6 hose from pump to fuel rail and back with all aeroquip fittings. Just ordered quit a few meters of hose and all fittings needed and made all the pipes up myself. On push on fitting is coming out of the tank as didn't fancy having a fitting welded on.
Mines all done in the stealth black hose and fittings from Torques. All very neat and looks the part.
Old Feb 18, 2018 | 01:09 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I did my entire fuel system with aero quip. Even had the standard rail and fuel tank modded to dash fittings. I’m -8 supply and -6 return. Every thing came from torques. I find there very helpful and knowledgeable on the phone and it’s all fast delivery
Old Feb 18, 2018 | 03:59 PM
Cossy Mike's Avatar
Cossy Mike
Does anyone know if the Goodridge hardline fittings will go straight on a std Fuel line?
This would save a lot of work having fittings welded on the ends of all the lines
Old Feb 18, 2018 | 05:10 PM
tosh's Avatar
tosh
I use these guys http://atecautotechnic.co.uk/en/
You can purchase the materials from them and make it up yourself if you are able to bend it, or you can give them you’re old ones or a template and they will make it up for you with adapters to fit.
I used the black polymer coated tubing and fittings to do mine, also done all the brake lines in stainless steel but needs a decent flaring to for the ends.
Old Feb 18, 2018 | 05:30 PM
I used 8mm copper pipe and used the original fittings.
Old Feb 19, 2018 | 10:38 AM
Cossy Mike's Avatar
Cossy Mike
Did you use the hardline fittings? I'm guessing the fuel pipe is 8mm to make it work?
Attached Thumbnails Fuel lines and fittings-cb7c4ea6_f15f_469b_81d0_d7da08284126_73a85323121bb63eb45b14d0c36ec9cdd4dcca53.jpeg
Old Feb 19, 2018 | 01:45 PM
tosh's Avatar
tosh
Yes mate I used their 8mm tube the external diameter was 10mm so not sure if it fits the original clips, it was their hardline fittings I used not sure if they are interchangeable with other brands.
Old Feb 19, 2018 | 08:27 PM
Cossy Mike's Avatar
Cossy Mike
That looks a proper nice job 👍
I had a look om the website, I could only find the fittings, no tubing on there. Maybe they done Mail the pipe
Old Feb 19, 2018 | 08:46 PM
tosh's Avatar
tosh
Your right Just had a look on their web site and it’s not there! But if you look on the bottom of their web page and download the online catalogue and go to page 19 it’s on there mate.
Old Feb 20, 2018 | 03:59 AM
Cossy Mike's Avatar
Cossy Mike
ok thanks
can you remember off hand tge approx cost of the tubing?
Old Feb 20, 2018 | 08:26 PM
tosh's Avatar
tosh
I think it was about Ł10 for a 3mtr length but that was a fair few yrs ago so has brobably gone up by now.
Old Oct 26, 2018 | 07:30 PM
timsrs's Avatar
timsrs
Has anyone used hardline fittings on tank
the 8mm return that’s on the tank is 20mm
not sure this is enough for a fitting
Old Oct 26, 2018 | 08:27 PM
tosh's Avatar
tosh
Because I replaced the plastic return pipes with the hardline I preferred to leave the short piece of rubber pipe between the tank and the return pipe for a bit of flex, I wasn’t happy with having everything solid for vibration purposes, I also put another rubber hose a bit further up just in front of the fuel pump and filter cradle, I don’t think this would be a problem as the return is low pressure.
jim cone
Mar 18, 2013 08:24 PM
haz87
Oct 28, 2009 03:37 PM
rog
30
Oct 20, 2008 10:35 AM
luxembourgrst
Feb 4, 2008 04:48 PM
