carb issues
Old Feb 17, 2018 | 10:09 AM
landaqmabba's Avatar
landaqmabba
Default carb issues
Hi, I need some help identifying my carb.
I have an 87 Sierra 5 door with a 1.3l pinto engine.
It used to run fine but my father left it without fuel we filled her up and worked for a few days, now on cold starts it misses feels like it s a 3 cylinder, after it warms up choke stays on and remains revved up also it feels without pull like it's missing tourqe.
I took the carb apart cleaned it and reinstalled it. so now it's working better but still choke stays stuck sometimes it chokes itself while running and stalls it's a pain to drive. So i replaced the vacuum pipes but it's still running rough.
So, does anyone know of a company or from where i can fin a manual choke conversion - carb has that variable venturi thing.
What carbs can i fit if i replace it, does a ford IV from a pushrod work given the correct manifold? or is it too small? as i have plenty of these lying around does a twin choke work?
Thanks for your time,
Dan
CapriChris
Jun 15, 2013 09:59 PM
l0ubie
Aug 9, 2010 03:38 PM
dean_orion
Jan 15, 2009 06:39 PM
markc
14
Jul 22, 2007 04:12 PM
markc
Jan 15, 2007 02:13 PM
