Fiesta mk6 Recirculation light keeps coming on
Old Feb 3, 2018 | 02:33 PM
messimagician's Avatar
messimagician
Default Fiesta mk6 Recirculation light keeps coming on
Hi guys
I'm having trouble with the air recirculation keep turning itself on. Often I will be driving for a bit then it just turns itself on, some times it won't turn off when pressing the button and the light will faintly stay on after turning the ignition off.
I find myself having to open the windows more now because of moisture build up
I took the car into a garage and they said it was tricky and not a simple case of replacing the button. The button is controlled by a £300 controller or something
I was just wondering if what I was told sounds likely to be the problem or if it could be something else and be an easy fix
Thanks
Simon78
Apr 6, 2016 08:42 PM
STEESHAZ
Mar 30, 2015 10:03 AM
mark212121t
Fiesta RS1800/RS Turbo
Feb 23, 2014 08:47 AM
h4v0cagha
Fiesta's Other !
Dec 25, 2013 04:35 PM
