Escort cosworth + stack dash =🤷🏻*♂️
Old Jan 30, 2018 | 05:39 PM
Cosyjay's Avatar
Cosyjay
Default Escort cosworth + stack dash =🤷🏻*♂️
Need help iv fitted a stack dash in to my escort cosworth but I’m unsure how to wire up the speedo iv got 3 wires sticking out my original speedo but the dash comes with a magnet thingie
Old Jan 30, 2018 | 05:47 PM
Caddyshack's Avatar
Caddyshack
You need to mount the stack sensor on the front wheel hub, it can be set to read 4 bolts so it will see the 4 backs of the wheel studs on the back of the disc, i made up a tiny little bracket, if I can find it I will post it to you as I no longer run it on my Wrc hubs. It is simple though.
Old Jan 30, 2018 | 06:41 PM
Caddyshack's Avatar
Caddyshack
If you cut an L shape like this pic, drill the straight end last to the size of the abs sensor bolt and then fold at dotted line after drilling hole for the sensor and then hammer it to the contour of the hub.
T33omm
Jan 24, 2018 06:09 AM
RoryG25
Ford Focus RS
Jan 5, 2017 12:01 PM
rsstav
Apr 10, 2015 09:11 PM
CozzyKing
Mar 7, 2010 03:52 AM
EscortCosworthUSA
Jul 11, 2005 05:29 PM
