Ford Fiesta The Iconic Ford Fiesta started in 1976 and ended in 2023 bringing to a close this great cars run of almost 50 years.
fiesta/ puma conversion help
Old Jan 30, 2018 | 09:45 AM
st220kyle's Avatar
st220kyle
Default fiesta/ puma conversion help
Looking to do the conversion this year, was after some advice on the best way to go about what's needed.
Is any puma engine suitable? Are there different versions is what i mean.
Are any additional parts needed that aren't already fitted to a fiesta or puma?
Are the zetec s and 1.7 looms plug n play when swapped over?
Will my fiesta exhaust fit the 1.7 manifold?
Thanks in advance
Kyle
Old Jan 31, 2018 | 10:04 AM
Adam-M's Avatar
Adam-M
Remember not all pumas are 1.7, try get the tape ecu it makes the car pop and bang with a stainless exhaust
You need to rewire the reverse light and front fogs on the conversion but there was a guide of zsoc so is pretty easy
I’d change the timing belt before you fit engine and clutch aswell
Old Jan 31, 2018 | 10:12 AM
Adam-M's Avatar
Adam-M
Forgot to add you need the engine loom, key and transponder ring for ignition, also need to mod the fuel lines, exhaust I can’t remember if the manifold is different.
Get the puma gearbox aswell it has shorter gear ratios to the 1.6 fiesta, if you can be bothered fit the 1.6 final drive gears into the 1.7 gearbox, it gives a final drive of 4.25 and makes some difference to the little cars.
Old Feb 1, 2018 | 07:31 PM
st220kyle's Avatar
st220kyle
Thanks for the advice, I'm thinking of getting a complete car so i have all the bits but mainly so i can actually see it running before hand.
Old Feb 1, 2018 | 08:51 PM
Adam-M's Avatar
Adam-M
They are great engines and can take a beating
london_chris
Ford Puma
Jul 18, 2019 06:44 PM
Pumafezz
Ford Fiesta
Feb 2, 2017 06:59 PM
Cj fiesta
11
Jul 21, 2011 02:42 AM
matt-xr2t
Ford Puma
Jan 27, 2010 10:19 PM
cosrep
Fiesta RS1800/RS Turbo
Dec 21, 2009 10:06 PM
