New coolant tank
Old Jan 28, 2018 | 03:38 PM
muffster's Avatar
muffster
Default New coolant tank
Hello folks.
I need to replace the coolant header tank my 1989 2WD, common problem of it splitting and leaking.
Got a replacement used tank form ebay but the hose connections are different. My original tank has got the return hose connection at the top of the tank near to the filler cap. The replacement has got the flow & return connections next to each other at the bottom of the tank and the return in a larger diameter hose.
I think its a 4X4 tank, no doubt someone on here has fitted one. How it is done please, is there some sort of adaptor kit with larger bore pipe sizes?
Thanks.
Old Jan 28, 2018 | 03:39 PM
Caddyshack's Avatar
Caddyshack
I may have a brand new one in the garage, not sure which type it is, I will try and put a pic up.
Old Jan 28, 2018 | 04:49 PM
muffster's Avatar
muffster
Great thanks mate.
Old Jan 28, 2018 | 04:59 PM
martysmartie's Avatar
martysmartie
4x4 has a wider hose. Roose Motorsport do an adapter hose https://roosemotorsport.co.uk/ford-s...-hose-kit.html
Martin
Old Jan 28, 2018 | 05:11 PM
Ridgey's Avatar
Ridgey
4x4 tanks are far more available than 2wd ones.
Yes you have a 4x4 one.
A new 2wd one would probably be about a grand+ if one ever came up for sale.
Old Jan 28, 2018 | 05:13 PM
Caddyshack's Avatar
Caddyshack
If they are worth so much I cannot work out why someone doesn't make an exact replica and then control the supply, surely it cannot be that hard to make? Maybe I should buy one and send it out to China for a remake?
Old Jan 28, 2018 | 05:15 PM
martysmartie
Exactly and you would probably have to get in a queue with the concours guys who want them! I actually know a guy who has just got a 3DR project and managed to get one.
I always think though, you could buy one only for it to start leaking!
Martin
Old Jan 28, 2018 | 07:33 PM
Ridgey's Avatar
Ridgey
There was talk on a forum (here or rsoc) about remaking via Lazer printing method. Didn't seem to get off the ground though, or followed through anyway.
You'd want a brand new one to start with.
Old Jan 28, 2018 | 07:37 PM
Caddyshack's Avatar
Caddyshack
True but if you can buy for Ł1000 and sell it for Ł800 then it hasn't been a waste to get you the pattern.
Old Jan 29, 2018 | 07:44 PM
muffster's Avatar
muffster
Thanks for the link ill order one from Roose.
Does it matter that the return hose to the tank is below the water level?
Thanks.
Old Feb 1, 2018 | 04:45 PM
AndyPen's Avatar
AndyPen
Thanks.
Don't think so as ford used to do a kit that did the same thing. I was lucky enough to buy two of the last new ones and once I had fitted one of them to the car it didn't take long for it to distort sadly ;-(
The other is hidden away for safe keeping of course!
Old Feb 10, 2018 | 04:49 PM
muffster's Avatar
muffster
So, fitted the new hose and tank today after flushing the system out.
Topped it up and added 2 litres of anti freeze.
Ran it up to temp, needle is nice and steady on the gauge, got the blowers in the car running nice and warm and both sides of the radiator at the bottom are hot.
All seems good but the water level is all over the place. I though id got the correct amount in the tank but after running it for a while, turned off and took the cap off the level has dropped significantly. But when it running it holds steady at the correct level.
Any ideas why?
Thanks.
Old Feb 10, 2018 | 04:57 PM
martysmartie
It's normal for a drop after starting to loose a little, as it's makes it's way through both the system and heater.
I would top up with anti freeze, as 2 litres isn't a 50/50 mixture.
Martin
Jasu
Jun 5, 2016 11:55 AM
paceo
14
May 9, 2012 01:31 PM
bruny
Nov 23, 2010 12:08 PM
AJC
Apr 30, 2010 10:06 PM
mac456
Jul 28, 2009 12:57 PM
