Focus MK1 Misfire
Old Jan 24, 2018 | 08:58 PM
wingcmnndr's Avatar
wingcmnndr
Default Focus MK1 Misfire
Hi All, Hoping for a bit of help before I give in and end up in a mechanics . I Have a Focus MK1 2L Zetec Petrol Blacktop, Until recently it has been performing fine with a service done recently. All of a sudden I felt a judder coming from the engine. I Ran a Diagnostic Scan and came back with a P0304 Code, Misfire Detected. The Scan also showed the following errors P0141 - o2 Sensor Heater Circuit Bank 1 Sensor 2P1131 - Lack of Ho2S11 Switch - Sens Indicates LeanP0171 - System Too Lean Bank 1P0136 - o2 Sensor Circuit Bank 1 Sensor 2Now I'm by no means a mechanic but my understanding would be this is to do with the MAF Sensor and Lambda Sensor may have gone ? Would this the Cause of the misfire ? or not ? I have checked the spark plugs and HT Leads I have checked the Coil but not sure what Ohms Reading I should be getting back as ok. My Next Step would be to check the Injectors and pump again not sure what omhs readings I should be getting for that to be ok.The only other thing recently I have done was given the engine bay a bit of a clean and wiped some oil residue away from the rocker bay area so could it be due to that ? I Have Read the PCV Valve and the IAT Could also be the cause.I'm quite happy having a go at most things so any ideas or suggestions do feel free to mention.While I Had the scanner attached I pulled the latest Live Data Set too which may help diagnose the issue DTC_CNT - 1FUELSYS1 - 0L-FAULTFUELSYS2 - N/ALOAD_PCT(%) - 31.4ETC (F) - 163SHRTFT1 (%) - 0.0LONGFT1 (%) - 0.0RPM (/MIN) - 887VSS - (MPH) - 0SPARKADV ( ' ) - 22IAT (F') - -40MAF (LB/MIN) 0.077TP (%) - 16.1O2SLOC B1S12--B2S----O2B1S1 (V) - 0.035SHRTFTB1S1 (%) - 0.0O2B1S2 (V) 0.000OBDSUP - EOBDMIL_DIST (MILE) - 0Any and all suggestions greatly appreciated many thanks Jamie
Old Jan 25, 2018 | 07:02 AM
oldford's Avatar
oldford
No reply whatsoever.
maccas1985
Ford Focus RS
Oct 11, 2018 11:00 AM
nathyj01
Dec 6, 2014 10:09 AM
stilomitch6
Oct 21, 2014 10:00 AM
Neatrags
Sep 25, 2014 12:25 PM
