Celette datasheet / chassis build
Old Jan 20, 2018 | 10:21 AM
Mclellan1981's Avatar
Mclellan1981
Default Celette datasheet / chassis build
Hi, does anyone have celette datasheets for escort cosworth they would be willing to share?
I am building a Peugeot 205 and need the set up data for the build.
Also could be after some mounting brackets for the Celette MZ towers... anyone?
offshore the now but will post pics of the build and car as I go
Thanks.
Gary,
Old Jan 20, 2018 | 04:11 PM
3i Jim's Avatar
3i Jim
10 Year Member
We use celette jigs at work, I can have a look through our data sheet collection to see if we've got one. Can't help you out on the mz towers though, best bet is to try and find a bodyshop that's closing down that may have them. Sounds like a cool project.
Old Jan 20, 2018 | 04:32 PM
Mclellan1981
That would be excellent Jim
I have the MZ towers, just not the cosworth brackets to suit.
thanks.
Gary.
Old Jan 20, 2018 | 04:54 PM
3i Jim's Avatar
3i Jim
10 Year Member
You can hire the brackets, try bodyshop solutions ltd. If you struggle for Escort cosworth data try Sierra because they pretty much share the same floor and suspension points.
Old Jan 28, 2018 | 03:27 PM
ossie cossie's Avatar
ossie cossie
i got this ages ago
Attached Thumbnails Celette datasheet / chassis build-webescortcosworthallur0_zps9808d57c.jpg
Old Jan 28, 2018 | 03:28 PM
ossie cossie
i will try and get it bigger but im sure someone on here that is better at computers than me can sort that out.
Old Jan 28, 2018 | 03:31 PM
ossie cossie
if they do i would appreciate a larger picture something i can print out.
Old Jan 28, 2018 | 03:54 PM
Mclellan1981
Cheers for that.
Can you email to gm1981.gm@googlemail.com?
I will get it resized and send back.
If you want an A3 size laminated , please send me your address and ill send you a few laminated copy's.
cheers,
Gary.
Old Jan 29, 2018 | 01:21 PM
ossie cossie
email sent.
Old Jan 30, 2018 | 06:14 AM
3i Jim's Avatar
3i Jim
10 Year Member
I've checked our Celette data sheet collection, unfortunately we've not got either Escort cosworth or Sierra. Hopefully the dimensions ossie cossie put up will point you in the right direction
Mclellan1981
Jan 11, 2018 10:13 PM
bagginsRSturbo
22
Nov 20, 2012 08:46 PM
mikey p
Nov 3, 2011 11:27 PM
cossiechris
Apr 20, 2005 10:25 PM
Andreas
Sep 17, 2004 09:53 AM
