Sapphire Cosworth performance rear brakes
Old Jan 19, 2018 | 09:57 PM
timsrs's Avatar
timsrs
Default Sapphire Cosworth performance rear brakes
Looking for a performance upgrade for the rear brakes on my Sapphire Cosworth
There don’t seem to be slot of options or choice out there
What are people running on the rear
Ideally I’m looking at 4 pots with built in handbrake
Thanks
Old Jan 19, 2018 | 10:01 PM
james kiely's Avatar
james kiely
really is overkill tim ,and im not sure you will find a 4 pot with a built in handbrake .they usually are fitted seperatley .
if your cossie is 2wd it will swap direction very quickly lol
Old Jan 19, 2018 | 10:26 PM
martysmartie's Avatar
martysmartie
4x4 (vented) is a good upgrade.
Martin
Old Jan 20, 2018 | 12:04 AM
BillyEdmonds's Avatar
BillyEdmonds
Generally speaking Wilwood makes a 4 pot caliper with an integrated hand brake. Not sure about specific fitment for a Sapphire though.
Old Jan 20, 2018 | 12:57 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
If you have the 2wd solid disc then upgrading to the 4x4 vented disc setup is a very worthwhile upgrade imo.
I have done this on my 3dr. I think the only difficulty is getting a set of the wider 4x4 rear calipers.
Old Jan 20, 2018 | 07:24 AM
timsrs's Avatar
timsrs
Hi
Yes my car is 2WD
Heard about the 4x4 setup on the rear
Is the only benefit heat dissipation
Thanks guys
Old Jan 20, 2018 | 07:33 AM
Mark V8's Avatar
Mark V8
Reyland 300mm
Why not go bigger vented discs with the 4x4 caliper
Old Jan 20, 2018 | 09:20 AM
timsrs's Avatar
timsrs
Originally Posted by Mark V8
Reyland 300mm
Yep seen that but the calipers looks lost with the huge disc
But the discs do look good
Old Jan 20, 2018 | 10:39 AM
Ridgey's Avatar
Ridgey
No point what's so ever in getting 4pots for the rear of 2wd Saff imo.
It will only give you problems.
Old Jan 20, 2018 | 11:23 AM
Mad_Mat's Avatar
Mad_Mat
New Owner
Originally Posted by timsrs
Hi
Yes my car is 2WD
Thanks guys
Cant think of any other benefits.
Sure ive seen a picture of a 2wd car on a trackday with its rear discs glowing. The 4x4 vented setup is the only way to imo.
Old Jan 20, 2018 | 12:28 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I’ve a Reyland 300 kit on mine with 4x4 callipers. Only fitted it as the bigger disc looks better in the wheel
Old Jan 20, 2018 | 02:01 PM
timsrs's Avatar
timsrs
Ok
Looks like I will go with the 4c4 upgrade
Thanks for all the input
Old Jan 20, 2018 | 04:16 PM
martysmartie
Hi
Yes my car is 2WD
Thanks guys
Yes, the discs are the same size, that being 273 MM.
Martin
Old Jan 20, 2018 | 04:33 PM
timsrs's Avatar
timsrs
So it’s a direct replacement for discs and calipers
Old Jan 20, 2018 | 04:45 PM
Ridgey's Avatar
Ridgey
Me too, Reyland 325mm kit
Old Jan 21, 2018 | 11:55 AM
1374lee's Avatar
1374lee
Yep 4wd upgrade is best. I got some 4wd calipers and had them refurbished, bought new 4wd discs and pads and some 4wd rear disc guards/backing plates,job done.
Thanks. Lee.
Old Jan 21, 2018 | 01:31 PM
timsrs's Avatar
timsrs
Thanks. Lee.
Yep that’s my plan
Forgot about the backing plates
Old Jan 21, 2018 | 02:32 PM
Marc sierra's Avatar
Marc sierra
On my 4x4 I also have the 325 mm kit from Reyland. I have that to get the brake balance close to original after fitting 356 mm discs with 4 pots at the front. 4 pots at the rear will probably upset the brake balance, but that depends on the size of the pistons.
Old Jan 22, 2018 | 10:06 PM
turbotrev's Avatar
turbotrev
When going from 2wd to 4wd rears and staying the with the standard disc size is there any real difference in brake performance?
Or is the vented discs just needed when going for a bigger diameter?
Is there enough braking force on the rear to actually warrant hanging from the standard 2wd setup?
Cheers Paul
Old Jan 22, 2018 | 10:30 PM
ajamesc's Avatar
ajamesc
I was told originally at the time fit 4x4 rear brakes so they don’t get as hot
Old Jan 23, 2018 | 09:06 AM
Marc sierra
IMO how much braking force you want on the rear should depend on how much you have at the front, in order to get a good brake balance.
Old Jan 23, 2018 | 02:03 PM
1374lee's Avatar
1374lee
Default protect
Yep that’s my plan
Down to personal preference some run without the backing plates others get new 4wd plates.
Cheers Paul
They cool much better due to being vented.
Thanks. Lee.
Old Jan 24, 2018 | 12:34 PM
turbotrev's Avatar
turbotrev
Thanks. Lee.
Do you think they actually brake any better though?
Performance wise?
Unless your on the brakes a lot especially being rears would it make that much difference?
Cheers Paul
Old Jan 24, 2018 | 03:01 PM
Loomer's Avatar
Loomer
Depends how the car is used really, on Ronnies Time Attacker on track the rears in std 2wd form, with good pads were fine at around 400-450bhp, but the moment we went over the 500-550bhp a set of rear pads would last ONE session out on track, we could literally put a set of pads in it, he would go out for 4-5 laps and come in with the pads white hot and no material left on them. the Std 4x4 Discs and callipers resolved the issue straight away, so they certainly work better in terms of cooling, but if anyone could possibly reach the limit on the road is another question.
Old Jan 24, 2018 | 08:28 PM
2wd's Avatar
2wd
Thanks. Lee.
Hi..is it still possible to get these rear disk guards....? As mine has never had some .. well since I got it in 95..?
Old Jan 27, 2018 | 11:19 AM
1374lee's Avatar
1374lee
Do you mean 2wd guards? If so then no Ford do not supply them anymore.Mine have been removed though.If you mean 4wd guards then Monster off here and on the escos site made a set for me.
I hope this helps.
CheeRS.Lee.
Old Jan 27, 2018 | 11:24 AM
1374lee's Avatar
1374lee
Performance wise?
Cheers Paul
Hi Paul.Well more air with the vented discs is gonna lead to keeping the brakes cooler again though dependant on how you drive and brake in the car I guess.
My complete braking on my car was horrific even after a good brake bleed with quality Dot 5.1 fluid and fitting new braided brake hoses.
Hence why I have gone mad and had the all new 4wd rear set up, all new refurbed calipers all round and all new performance discs,pads etc.Hopefully it will be far better than the old tired set up.Fingers crossed.
Thanks. Lee.
Old Jan 27, 2018 | 06:19 PM
2wd's Avatar
2wd
I hope this helps.
CheeRS.Lee.
Well my car is 2wd, but I run 4wd rear brakes...thanks
Old Jan 27, 2018 | 06:20 PM
ajamesc's Avatar
ajamesc
My guards went in the bin when I fitted a bigger rear barke kit
Old Jan 28, 2018 | 03:03 PM
1374lee's Avatar
1374lee
Contact Monster if you you need a new set of 4wd guards.
Yes, they are no good for the larger brakes as you say.
CheeRS.Lee.
Old Jan 28, 2018 | 03:37 PM
2wd's Avatar
2wd
CheeRS.Lee.
Ive done that...just waiting ..
Thanks.
Old Jan 28, 2018 | 03:48 PM
timsrs's Avatar
timsrs
Does anyone know the contact for monster
Cheerd
Old Jan 28, 2018 | 04:02 PM
costina's Avatar
costina
Live long and prosper!!
No good for a Sierra they are more for kit cars.
we have used them on cars at work but the handbrake is just a parking brake.
Old Jan 28, 2018 | 04:06 PM
costina's Avatar
costina
Good advice.
I run 4x4 vented rears on mine.
Trick is good quality discs and pads and calipers which are in good working condition.
Reyland do a big disc conversion which uses std vented calipers so that would be the next step up.
Old Jan 28, 2018 | 06:53 PM
turbotrev's Avatar
turbotrev
I have standard 2wd rears on mine with grooved discs, but I also have 4wd calipers off my old saff so am contemplating which to use, I will go uprated pads in whichever I choose anyways.
I’m thinking staying 2wd as 1) I already have grooved/decent discs and 2) they weigh less, I know that sounds a little gay but my car will be going on a diet once going back together.
I also don’t think I’ll ever cook them as I won’t be doing any track days or super hard braking use (and it is the rear, the fronts are going bigger)
Cheers Paul
MT-Motorsport
42
Feb 11, 2013 04:31 PM
kaking1982
Jul 29, 2011 12:51 PM
Sonic Boom
11
Dec 9, 2008 10:13 PM
Rax
Oct 13, 2008 04:22 PM
wimwerf
Oct 12, 2005 07:35 PM
