Fitting the Cosworth auxilary belt pulley
Old Jan 19, 2018 | 02:12 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Default Fitting the Cosworth auxilary belt pulley
I've come to the stage where I should fit this, the inner cam belt pulley went in easily but the outer pulley seems very, very tight? Should it just slide in with no real force? I cleaned the crankshaft snout properly, put little bit of engine oil on it, and the outer pulley still doesn't want to go in all the way. I managed to slide it almost in (5 mm shy of being in all the way) by tapping it with rubber hammer.
How tight this should be when putting it back in, I remember it was anal to get out but after proper cleaning it seems to require more than bare hands to get it back in. Is this normal?
Old Jan 20, 2018 | 08:00 AM
Jules44's Avatar
Jules44
10 Year Member
My one slides on and off, but not at first though I cleaned it all up with some scotch brite then applied some copper slip it’s a nice snug fit now
Old Jan 21, 2018 | 01:06 PM
Cossie92's Avatar
Cossie92
Cossie newbie
10 Year Member
Ok so apparently the basic cleaning wasn't quite enough. I'll see if I can drive it all the way in gently with the crank bolt, if not I'll remove it again and use scotch brite.
Old Jan 23, 2018 | 07:54 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Some of them are tight as fuck. I've never had a problem with 2wd pulleys, only 4x4's so maybe there is a very small difference in the internal hole diameter of the pulley.
Cossie92
Sep 9, 2017 10:14 PM
Twellsie
Nov 24, 2008 06:42 PM
SiZT
Sep 29, 2008 11:49 AM
