Focus Mk2.5 - Wet boot & passenger footwell
Hi all,
What with this recent bad weather, my passenger footwell & drivers side corner of the boot are wet.
Any idea's why?
When it's dry, I will dismantle the boot of it's plastics & hopefully it will be obvious but no idea on the passenger footwell.
Car is a 2010 Mk2.5 Focus ST.
Thanks
Andrew
Any idea's why?
Thanks
Andrew
They seemed dry as the only wet place in the boot is where the tyre repair kit is.
I have taken the boot apart & possibly it the rubber gasket that holds the rear light onto the car.
Not 100% on this but we will see tomorrow if it rains.
Still no idea on the passenger front.
Well, I replaced the plastic / foam screws that hold the rear lights in but that made no difference. Then stripped a bit more trim out the pillar / boot area. Think that it is coming in from the boot hinges or the welded seams is the channel between the roof & boot. Got some clear silicone sealer to cover any join. Hopefully that works. If not, its the roof gutter.
dead common issue on mk2 s youtube has loads of vids on it and appears to be mainly from light screws and hinges as somehow at hinges the water is almost sucked up and runs down between panel gaps collecting in bottom corner of the boot, had a st and ghia both do it in same place
I have replaced the plastic & foam light screws but no difference. I have been using kitchen roll & old flannels to stop it getting in the boot so it isn't as bad. I now have some clear silicone sealant & will be sealing everything I think it could be.
Also, some forums say it could be the roof gutter.
I think now that my damp passenger footwell is an air conditioning leak as the 'water' dries on my hand sticky so its coolant. Think it may be a damaged pipe or seal. Off to Ford for that.
Went out in the focus today and noticed that i have also got a wet boot, but on the passenger side. looks like mine is coming in behind the light, i took it off to see what was going on in behind and i cant believe what a shit design it is. I surprised these don't all leak water from new! how did ford expect the 2x screws and 2x pegs to keep water from leaking into the boot?!
I've never taken a rear light out before so it was full of crap in behind, retaining the rain water.so I'm hoping just cleaning it out has sorted it for me.i will check again tomorrow and see.
https://www.hendyeshop.co.uk/nut---a...07-30984-p.asp
NUT - ADJUSTING F1211807
I have since added silicone sealant around them & to every seam on that side of the car & touch wood, its been ok but it hasn't been heavy rain so far. The main culprit is likely to be the boot hinge area, that square section the hinge goes into. Seal behind the hinge aswell. If that still leaks, its the roof gutter but will order a new trim part before I attempt to remove mine.
I did however have a hole in the sealant Ford put in in behind the rear bumper in one of the cavitys. If you put a torch on the ground by the exhaust tip, you could see it through the boot.
Water getting in and puddling the spare wheel. I can tell you exactly where its getting in. My my other half bought a 55 plate Focus a couple of years ago, and seemed nice and clean with low miles for age. Opening the tailgate after a couple of days worth of rain, there must have been a gallon of water in the boot along with a drenched boot carpet. After much searching, taking out light clusters etc, all to no avail, I shoved my missus in the boot with a torch and went round the rear of the car with a fairy liquid bottle full of water and found it to be the welded seal near the tailgate hinge, following right behind the roof rail. Some clear bathroom sealer injected and smoothed off solved the problem for good. its a tiny gap that you wouldn't believe lets so much water in.
Just for anybody who is looking for info.
Boot was water leaking in via the seams around the boot hinge, that square box the hinge is in. Also sealed up all the seams in the area just in case.
Water in the footwell was due to cracks in the bulkhead seams, about 2" below the windscreen. Done from inside the car, glove box out, all the old material chiselled out then re-sealed. Sorted on the 3rd attempt.
my MK 2.5 focus boot leak, after lights out, roof rails off and head lining out, and re fitted, turned out to be the joins in all the panels near the hinges on the boot lid, I used some clear sealant something like Stixall, cured the problem. I have just got a leak in front passenger footwell, let the world know how i get on with that if and when i sort it.
These cars are horrendous for boot leaks really poor quality. I’ve just fixed my st for the same fault I had a few attempts then got pissed off with it and sealed everything I could find on google about them leaking. I removed the rear bumper and sealed the air vents and the plastic clips that the 2 8mm bumper bolts screw into. I removed the rear lights sealed the wire grommets and the 2 rubber grommets under the rear lights that do nothing. Also again sealed the plastic clips that the rear lights screw into. I then masked up either side of all the panel seams around the boot area and the boot hinges and sealed them. Also lifted the roof rails and sealed all the cracks I could see. I used tiger seal as my cars black luckily. Mine doesn’t leak anymore and we have had some very heavy rail. Also fitted a new boot seal
I've been having a wet drivers footwell now. Had the wipers, wiper motor and scuttle panel off and loads of cracks in the seam sealant were found. All dug out and re-sealed. Then it still leaked. A new crack found that wasn't there the first time. Sealed that. Now it seems ok but still a bit wet. Not sure if it just normal damp / sweating or its still leaking.
Passenger side was the same, seam sealant cracks.
Boot … no idea where but sealed the light holes and all the seams in that area and the boot hinge pockets. Been dry but a but paranoid that if I clean it, I will disturb it and it will leak again.
Hi,
I was experiencing this problem of lots of water in the boot in the spare wheel compartment, which had caused my back seats to become damp. And also a puddle of water in the passenger side rear and front foot wells, but I found a video on YouTube where the issue was identified as water leaking in behind the rear light.
See the following link -
I hope this helps, was a much better option than paying Ford £120 an hour which they quoted me.
the wood man
May 9, 2010 08:50 PM
