What throttle body to use ..
I've got a S1 inlet that's having a Fuel rail fabricated to allow injectors for manangment conversion ..im wanting to know what throttle body is everyone using ..ive seen cosworth ones being used ..but there mega bucks now ..is anyine else using anything different that's cheaper and easier to get hold of ?
Many thanks Mat.
Many thanks Mat.
Fiesta turbo throttle body would be fine mat and pretty cheap or go for a cfm 76mm one there a few hundred quid for a zetec and have a plate welded on to match throttle body holes. I used a fiesta rs 1800 inlet and a fiesta turbo throttle body as I used ofab management and it allowed for manual adjustment of the throttle plate so I binned the idle speed control valve.
Cheers paul
Cheers paul
VR6 is a good shout, you need an early pre 1995 body as the post 95 had a stepper motor for idle control.
VR6 TBs are 75mm IIRC.
Should be able to pick one up cheaper than this tbh...
https://www.ebay.co.uk/itm/VW-Golf-M...EAAOSwsIZZnJuF
Yea I'm installing storm ..but I'm going to run s1 inlet on a cheap easy to fit throttle body first ..untill further in the year when ill go for a bespoke inlet mate .
Mat I used a s2 inlet with s1 throttle body and fitted a jenvey /Colvern throttle position sensor from emerald. Blanked the aux air device outlet off so no idle valve ..set the cold /warm up idle in the ecu .might need to adjust the flap stop to give enough air on tickover.
matt i bought a ecu the other week off madmatt on here and he threw in a tps for free so your welcome to it mate .
im just returning your favour from a few year back with the comp centre caps
just pm me your address and i will try get it in the post tommorow
Please mate that would be awesome ..really appreciate that ..let me know the postage mate ..and I did the same other week with a guy with a fucked metering unit ..just gave him my spare working one ..he couldn't thank me enough ..
Many thanks Mat.
Many thanks Mat.
cozy777
Feb 29, 2012 06:10 PM
1374lee
Mar 28, 2010 01:04 PM
bigryrs
Jul 4, 2009 06:49 PM
