Where does cossie ECU read rpm from?
Old Nov 14, 2017 | 06:46 AM
rog's Avatar
rog
Default Where does cossie ECU read rpm from?
I have this problem with my 4x4, there is sometimes a misfire and the SECS monitor rpm intermittently reads high, indicating a wiring fault somewhere. Where is the rpm take off, anyone know??
Old Nov 14, 2017 | 07:21 AM
oldford's Avatar
oldford
The rpm is calculated by the engine management system from the time between the pulses of the crankshaft.
Old Nov 14, 2017 | 10:31 AM
Jay,'s Avatar
Jay,
Sponsor
Is it the original engine loom Rog if so remove the connector blocks off the loom at the bulkhead and hard wire it they always do this
