Sequential injector firing
Old Nov 7, 2017 | 08:21 AM
Rsmat's Avatar
Rsmat
Default Sequential injector firing
My CVH build is a EFI block with CPS and flywheel ..am I right in thinking to go sequential Fire that all i need is a cam pickup ? My managment supports sequential so if it easy enough i might aswell use it and order the loom to suit ..just wondering if it's just a case of the cam pick up needed ??
Many thanks Mat.
Old Nov 7, 2017 | 08:48 AM
Jay,'s Avatar
Jay,
Sponsor
Yes a cam sensor is required
Old Nov 7, 2017 | 09:21 AM
james kiely's Avatar
james kiely
Could you run a 36_1 toothed crank pulley jay
Old Nov 7, 2017 | 09:34 AM
Rsmat's Avatar
Rsmat
No need the EFI block has a CPS and picks up off the EFI flywheel mate..crank pick up is sorted ..i just need to get a pick up sorted for the cam as jay says .
Old Nov 7, 2017 | 12:40 PM
jonfoc's Avatar
jonfoc
Jano does a nifty little cam trigger set up may
Old Nov 7, 2017 | 12:58 PM
Jay,'s Avatar
Jay,
Sponsor
you would still need a cam sensor james
Old Nov 7, 2017 | 04:26 PM
Rsmat's Avatar
Rsmat
Yea just looking at those now mate ..cheers .
