Cosworth hydraulic clutch question
Old Oct 27, 2017 | 02:55 PM
luke_rs1800's Avatar
luke_rs1800
Default Cosworth hydraulic clutch question
Has anyone used a cosworth hydraulic clutch conversion kit from brands hatch performance ? It looks identical to the turbosport one. However the turbosport listing now states you no longer need to use shims. Can anyone shed some light on if these are the same or not ? Thanks
Old Oct 27, 2017 | 03:14 PM
R4N SS's Avatar
R4N SS
seen it to as said on your facebook post and am interested in this also.
Old Oct 27, 2017 | 03:34 PM
Caddyshack's Avatar
Caddyshack
If their listing says you no longer need the shims then I would assume it is different in some way seeing as they have gone to the bother of adding that to their advert.
Old Oct 27, 2017 | 04:20 PM
luke_rs1800
Obviously..... I wondered if anybody knew the difference. As they look identical. One is more expensive than the other. And both use mondeo v6 slaves I believe. More to the point has anyone used a brands hatch one ? Are they any good or the same.
Old Oct 27, 2017 | 06:17 PM
Caddyshack's Avatar
Caddyshack
I thought the slaves were E30 BMW? It has been a while since I did mine.
Old Oct 28, 2017 | 05:52 PM
COLEYST200's Avatar
COLEYST200
the BMW E30 slave is used on the out side the gear box setup . I think the lads are talking about a center push setup
Old Oct 28, 2017 | 05:59 PM
Jay,'s Avatar
Jay,
Sponsor
Unless buying tilton the centre push stuff people use are really bad like the Mondeo one they break very quickly so I have fitted plenty of e30 bmw yo many and not had many failures and if there is then there easier to change
Old Oct 28, 2017 | 07:13 PM
Adam-M's Avatar
Adam-M
The op is talking about centre push conversions where as I believe the BMW e30 is external slave which I prefer as you can change quickly without removing the gearbox.
Old Oct 29, 2017 | 08:25 AM
COLEYST200's Avatar
COLEYST200
i think it's the look of the droor on all of them iv had 1 e30 slave go on me on my 3DR . And My mate rex has had 2 go on him . And iv been running a mondeo centre push on my skyline gearbox for over two years now and it's still going strong and it was only a cheap one off ebay .
Old Oct 29, 2017 | 09:11 AM
jonfoc's Avatar
jonfoc
Maybe it has something to do with the clutch you are engaging/disengaging. If your trying to move an uprated clutch with a cylinder that’s not rated to that pressure it’s going to fail.
Old Oct 29, 2017 | 10:37 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I’m fitting a tilton Center push to mine there reliable and not that expensive to be fair. I thought about the side push but it’s a cheap fix made for a normal pressure plate. Plus it sits fooking close to the gearbox tunnel
Old Oct 29, 2017 | 01:36 PM
Caddyshack's Avatar
Caddyshack
I used the tilton when I did the skyline conversion, I think I still have the mounting plate if you need it.
Old Oct 29, 2017 | 01:42 PM
ajamesc's Avatar
ajamesc
Ive not ordered it yet I chatted to them on the phone I have to wait unti I get my engine so I can give them the block to clutch fingers measurements then I can get it all ordered up
Old Oct 30, 2017 | 11:24 AM
Jay,'s Avatar
Jay,
Sponsor
Exactly a decent clutch will foul a mondeo center push and like I said the e30 one seemed more reliable and deffo easier to change
Old Oct 30, 2017 | 12:14 PM
R4N SS's Avatar
R4N SS
anyone got any links to what i need to buy - e30, etc?
Old Oct 30, 2017 | 03:00 PM
Adam-M's Avatar
Adam-M
I'm just gonna go for the Reyland one as the price includes tig welding a bracket to your bell housing. Plus with all the other stuff I need to buy I can't be arsed peicing together a kit lol
Old Oct 30, 2017 | 03:48 PM
R4N SS's Avatar
R4N SS
but then you have to send the housing off to them?
Old Oct 30, 2017 | 03:54 PM
Caddyshack's Avatar
Caddyshack
The reyland one on the side push comes with a steel weld on lug that you MIG to the steel clutch fork, no need for bellhousing mods on the side push...apart from drilling holes in it. Not sure about the centre push as Coley made me an adapter for the Ford centre push before I went over to the Tilton.
Old Oct 30, 2017 | 08:12 PM
james kiely's Avatar
james kiely
i thought you needed a small bracket welded to the bellhousing on a t5 toby
you can drill the 4wd bellhousing alright
Old Oct 30, 2017 | 08:18 PM
Caddyshack's Avatar
Caddyshack
Sorry James, I was thinking only of the 4wd.
Old Oct 30, 2017 | 08:30 PM
james kiely
i only know this because i need the bracket mate lol
Old Oct 30, 2017 | 10:19 PM
cossynut2's Avatar
cossynut2
10 Year Member
You do, but I found it fairly simple to get the bell housing up to them and returned ready with the lug welded on.
Old Oct 31, 2017 | 09:16 PM
155lee's Avatar
155lee
I’m interested in this mod also.
Anyone got any pics of the master cylinder installed in the engine bay?
Or is there a way to fit the cylinder inside so you don’t see anything inside the engine bay?
Old Oct 31, 2017 | 10:25 PM
cossynut2's Avatar
cossynut2
10 Year Member
This is how mine looks in the engine bay, nice and neat.
Old Nov 1, 2017 | 11:01 AM
Jay,'s Avatar
Jay,
Sponsor
Trying to remember I think it was cossiejeff or something like that when building his rather nice moonstone 3 door he put a very good post up with info on the whole conversion for 2wd
Old Nov 1, 2017 | 11:41 AM
155lee's Avatar
155lee
I want to do it but I’d rather spend a bit more time trying to get everything in behind the dashboard so there’s nothing visible in the engine bay except a green brake pipe running to a flexi then onto the bellhousing.
Not really at this stage yet but something I need to look into soon.
Old Nov 1, 2017 | 11:42 AM
155lee's Avatar
155lee
Edit-double post
Old Nov 1, 2017 | 02:08 PM
R4N SS's Avatar
R4N SS
group buy
Old Nov 1, 2017 | 06:37 PM
2Litre's Avatar
2Litre
I have the reyland conversion on mine, although I changed the master cylinder from a .6 to a .75 as this gave me a better travel. The slave is a E30 bmw one 20 odd quid.
It is one of the best conversions I have done, the master cylinder is hidden behind the heat-sheild. The only visible item is the reservoir which I am sure can be hidden somehow.
Tim
Old Nov 1, 2017 | 10:23 PM
cossynut2's Avatar
cossynut2
10 Year Member
Tim
Same as mine. I think the reservoir blends in well in the engine bay and looks like its always been there and also you need to be able to easily check the fluid level.
Old Nov 2, 2017 | 04:36 PM
cozzy jeff's Avatar
cozzy jeff
i did but thanks to pbotobucket you cant see the pics🙁
Old May 5, 2018 | 09:59 PM
cossie51's Avatar
cossie51
Anyone know if the Reyland centre push kit is any good ? I'm guessing it's not the cheap slave as they recommend it for their heavy duty clutches.
Old May 6, 2018 | 10:08 PM
cozzy jeff's Avatar
cozzy jeff
i have the reyland centre push and a cheap master cylinder and its been good for over 6 thousand miles.
clutch is ap 6 paddle with standard cover.
its all coming apart again next year for an engine build so will be interesting to have a look at the clutch ect to see how its looking
Old May 10, 2018 | 07:07 AM
Sotvispen's Avatar
Sotvispen
I bought a centerpush kit from brand hatch for my t5, but the adapter came with wrongdrilled holes for the slave. The slave is a mondeo type.
They assured it woudnt fail, but im not sure...
What mastercylinder size is recomended?
Im using a ap 6 paddle kit.
Old May 10, 2018 | 04:36 PM
Caddyshack's Avatar
Caddyshack
I think the one for Reyland centre push is very like the mondeo or v6 sharan iirc.
Old May 10, 2018 | 08:41 PM
cozzy jeff's Avatar
cozzy jeff
im using .7 on mine
Old May 10, 2018 | 08:44 PM
Caddyshack's Avatar
Caddyshack
The centre push needs to be very exact or it won’t work well
Old May 10, 2018 | 08:55 PM
cozzy jeff's Avatar
cozzy jeff
my centre push.
Old May 11, 2018 | 02:35 PM
Caddyshack's Avatar
Caddyshack
Originally Posted by cozzy jeff
my centre push.
That’s the one like Reyland that I had
Old May 13, 2018 | 06:31 AM
Sotvispen's Avatar
Sotvispen
im using .7 on mine
Ok, think i would go for that.
Do you have any stop on your pedal or how have you done to adjust the length on the slave?
