Any difference, Ford DOHC (I4) heads.
Old Oct 18, 2017 | 04:38 AM
Nilssen's Avatar
Nilssen
Default Any difference, Ford DOHC (I4) heads.
Hi.
Could I stick a 2.0, 16V scorpio head on a 2.3 galaxy bottom without the compression rate getting to high? or are they the same?
Regards
Daniel.
Old Oct 18, 2017 | 08:30 PM
Mark V8's Avatar
Mark V8
Combustion chambers are smaller on 2 litre head and will raise the C.R
That being said a lot of the RS2000 boys get away with using the 2 litre head on 2.3 bottom end.
I skimmed a 2.3 head to raise the C.R when I did a 2.3 conversion many years ago and used RS2000 cams.
Make sure you use the 2.3 head gasket.
Old Oct 19, 2017 | 08:31 AM
Nilssen's Avatar
Nilssen
Thanks Mark.
