Unknown Cosworth Wiring Plug
Old Oct 16, 2017 | 07:11 PM
wood85's Avatar
wood85
Default Unknown Cosworth Wiring Plug
Distributor, Crank Position Sensor and Idle Control Valve are connected to this part of the loom, this remaining plug is spare. I've borrowed a picture to show all the plugs.
http://i182.photobucket.com/albums/x...=1508180219133
It appears to be a cable much larger than standard 1.5mm coloured wires with a copper outer.
Can you help identify the plug please?
Old Oct 16, 2017 | 07:30 PM
bigdel's Avatar
bigdel
Could be the sensor (air temp) in the plenum.
It goes in the threaded hole in the middle of the plenum in this picture
Old Oct 16, 2017 | 08:40 PM
steppy's Avatar
steppy
Here's a useful site with diagrams,
http://www.bigturbo.co.uk/main6.htm
Get a multimeter set it on continuity and check where it goes
Old Oct 17, 2017 | 04:17 PM
wood85's Avatar
wood85
Thanks for your help guys. This was the knock sensor plug apparently, I don't have a knock sensor though. Will leave it disconnected.
