Seirra 8v DOHC efi
Old Oct 6, 2017 | 02:46 PM
axle's Avatar
axle
Default Seirra 8v DOHC efi
Hi All
I was looking for head gasket for the above ,
1) Apart from Burton where do I go we have had this before on the forum that they are expensive but what choice do we have?
2) Has anyone fitted 16v DOHC as a replacement to the 8v DOHC as the opinion is the 16v DOHC is stronger as they are of the same block?
3) Should I really use new cylinder head bolts or will get away with the original if they torque up Ok?
Cheers axle
Old Oct 6, 2017 | 03:07 PM
Adam-M's Avatar
Adam-M
MLS head gasket set...
https://www.ebay.co.uk/itm/200324985810
I'd never re-use head bolts on an engine unless they where long stud type in a yb.
Old Oct 6, 2017 | 06:34 PM
axle's Avatar
axle
Thumbs up
Thanks for your reply I had seen them on Ebay I take you are happy with what you got from them?
I see why I should use new bolts now
Cheers Axle
Old Oct 6, 2017 | 06:52 PM
Adam-M's Avatar
Adam-M
I haven't used that set as I don't have that engine but I have read people recommend it on crustworld. I prefer metal head gaskets to fibre but surfaces need to be perfect.
Old Oct 7, 2017 | 02:39 PM
gcfcos's Avatar
gcfcos
http://www.crustworld.co.uk/
Some good info on here
Old Oct 8, 2017 | 11:01 PM
steppy's Avatar
steppy
I have fitted the genuine ford multi steel headgasket to my saph part number 1101405 iirc, its much better than the crappy fibre replacements you get from parts shops which I stupidly fitted first but i did manage to get nearly 10000 miles out of it before it went
As said new head bolts, also id recommend changing your timing chain and plastic tensioner while your at it to save you any heartache in the future
Old Oct 9, 2017 | 08:21 AM
BMrider's Avatar
BMrider
Where can you get new headbolts from?
Old Oct 9, 2017 | 09:24 AM
steppy's Avatar
steppy
Any motorfactors will get you some headbolts or ebay mate
Here's a set on eba​​​​​​y
https://m.ebay.co.uk/itm/FORD-SIERRA...%257Ciid%253A1
