clutch problem.....
Old Sep 28, 2017 | 06:21 PM
fuzzy's Avatar
fuzzy
14000+ post superhero
Default clutch problem.....
a new clutch and dual mass fly wheel was fitted to my work van at a cost of £960...got it back today but didn't even make it home (20 miles), the clutch pedal has went right to the floor and has stayed there. its selecting gear when engines off but not when engines running as the clutch pedal is stuck in the fully depressed position. its going back to the garage tomorrow but whats a likely cause? what have they done wrong?
Old Sep 28, 2017 | 06:31 PM
RichieST's Avatar
RichieST
Hydraulic clutch? If so air lock in the system possibly.
Old Sep 28, 2017 | 06:33 PM
focusv8's Avatar
focusv8
Would this be a Vivaro van?
Old Sep 28, 2017 | 06:52 PM
fuzzy's Avatar
fuzzy
its a Vauxhall combo, 63 plate. just passed the 100k miles.
Old Sep 28, 2017 | 08:57 PM
Adam-M's Avatar
Adam-M
I'd say airlock or dodgy mater cylinder, has it lost any clutch fluid?
Old Sep 29, 2017 | 05:19 AM
markie t's Avatar
markie t
THE REAL DEAL
10 Year Member
IN MY EXPERIENCE SOMETIMES WHEN YOU FIT A NEW PART IT PUTS EXTRA PRESSURE ON THE SYSTEM AND FINDS A WEAK LINK WHICH CANT COPE
Old Sep 29, 2017 | 08:05 AM
It's Czech Mate's Avatar
It's Czech Mate
SUCH AS THE CAPS LOCK BREAKING.......
Old Sep 29, 2017 | 12:26 PM
fuzzy's Avatar
fuzzy
Turns out they hadn't connected the hose to the master cylinder properly and the fluid had leaked out. The AA fixed it roadside. Useless cunts....
Old Sep 29, 2017 | 08:10 PM
stevieturbo's Avatar
stevieturbo
C**t
The likely cause is fucking morons !
Old Sep 29, 2017 | 08:11 PM
stevieturbo
C**t
just past 650k on mine....
The morons have probably fucked the rubber o-ring thingy where it disconnects at the bellhousing, or not clipped the clutch line in correctly.
Old Sep 29, 2017 | 08:12 PM
stevieturbo
C**t
A friend had a clutch specialist recover his van 3 times after they did a clutch on his...for the same reason. 3 fucking times ! And yes, a clutch specialist !! LOL
Old Sep 30, 2017 | 05:11 AM
markie t's Avatar
markie t
THE REAL DEAL
10 Year Member
i reckon you have spur marks on your van now!
Old Sep 30, 2017 | 10:37 AM
GVK.'s Avatar
GVK.
^^^ huh?
