Rs Turbo Crank bent
As title I took a working crank out of my engine and was going to use on the new build .. my engineer messaged me to say it was a tad bent but he's sorted it ..so alarm bells rang and I asked a few more questions and it was 2thou out which as far as.i understand hes ground it out ..is it still fit to use ???? in my new build ..the new build is forged and will be running some big boost ...
Thanks Mat.
Thanks Mat.
I actually panicked and sourced a brand new rare CVH crank at the cost of 420 quid ..but just wanted to know other people's thoughts as technically its straight now and was told Ford's manufacturers tolerances for the cranks was 5thou .
He told me it would be fine ..but the word bent made me panic ..i over reacted and sourced a new crank ..but now I'm sat wondering if it would have been ok since later finding out Ford's tolerance on the crank is within 5thou and mine was only 2thou out
I will now I have a new crank ..the threads more towards did i panic and didn't need too or not .?..if it's safe to use ill pass it on that's all as well.
Spending Ł420 on the new crank makes more sense than buying a turbo blanket!
Thanks mate ive managed to find a genuine brand new crank but ill be needing one now for the original engine I'm building back up along side my forged one ..pm me what ya want for it and I'll come collect it at some point.
If it's now been machined straight mate it'll be fine.
It's all nonsense about reground cranks being weaker blah blah.
The ammount removed is so minimal it'd make virtually no difference to strength
Cheers Paul
Cheers Paul
There can be some cranks that dont like being reground etc...
But in this case, we dont know exactly how/where this was measured, nor has it been stated exactly what was done to correct whatever problem they're saying there is.
cranks are measured for straightness on the mains, you usually set the ends up perfectly on the grinder and then run along all of the mains to measure for any bends. 2 thou is fine to grind out really though, it may have a minute effect on piston heights depending on what type of grinder was used, but nothing to worry about. 2 thou is about half the thickness of a bit of normal printer paper if you need an idea of how bent it was.
Thanks mate i did think it wasn't much to worry about .
If thats the case and it now runs true it wont make any diffence to its overall strength
Cheers Paul
Cheers Paul
