Turbo Blankets
Old Sep 16, 2017 | 10:36 AM
Rsmat's Avatar
Rsmat
Default Turbo Blankets
Are they worth fitting ..thinking of putting one on my turbo
Any benefits ?
Thanks Mat
Old Sep 16, 2017 | 01:39 PM
Ridgey's Avatar
Ridgey
Never seem to get a definitive answer to this one.
Benefit to turbo response apparently, but questions on the longevity of turbo life holding onto all the heat.
More heat transferred to the exhaust.
Old Sep 16, 2017 | 01:55 PM
Rsmat's Avatar
Rsmat
Most response ive had all say ..they just smoulder and catch fire .
Old Sep 16, 2017 | 02:05 PM
Ridgey's Avatar
Ridgey
That doesn't sound to great.
Old Sep 16, 2017 | 02:07 PM
Rsmat's Avatar
Rsmat
But I see a lot of race cars with them on ..unless its the cheap eBay ones people mean.
Old Sep 16, 2017 | 02:21 PM
Ridgey's Avatar
Ridgey
Probably, as they do get quite expensive from what I remember.
Also race teams will change or rebuild turbos frequently, since they have a budget for that.
Old Sep 16, 2017 | 02:27 PM
jonfoc's Avatar
jonfoc
I think I've got an expensive deli type one somewhere mate. You can have it cheap if I can find it. It's nearly new. I've used it and it never caught fire
Old Sep 16, 2017 | 02:28 PM
Rsmat's Avatar
Rsmat
Yea true ..im just reading a thread on it ..on another page it says it's a worthwhile mod for keeping engine bay temps down .
Old Sep 16, 2017 | 02:38 PM
jonfoc's Avatar
jonfoc
I've heard they're good but you must allow the car to cool properly after a good drive to avoid cooking the core.
Old Sep 16, 2017 | 03:30 PM
bigdel's Avatar
bigdel
have you considered getting the turbo housing ceramic coated?
Old Sep 16, 2017 | 08:23 PM
stevieturbo's Avatar
stevieturbo
C**t
Any benefits ?
Thanks Mat
Depends why you're fitting it.
If you need some heat protection for surrounding components, then yes of course it's worth doing ( a good quality one, not crap )
benefits are those surrounding components get protected lol.
If you dont need one, then there probably isnt much point. Any talk of performance gains...I'd like to see some proof on that.
Old Sep 16, 2017 | 08:48 PM
Rsmat's Avatar
Rsmat
I'd just like the keep as much heat away from the rad as possible mate .
Old Sep 17, 2017 | 11:00 AM
stevieturbo
C**t
Then get a good quality blanket
Old Sep 17, 2017 | 09:23 PM
cossynut2's Avatar
cossynut2
10 Year Member
Have you had problems with your engine overheating the radiator? Unless you have some monster turbo and are driving flat out all the time I cant see you will have any overheating issues. You probably have already fitted a larger high flow aluminium radiator, pre turbo cooler, large intercooler etc which will all help to keep engine temps down.
Old Sep 17, 2017 | 09:35 PM
Rsmat's Avatar
Rsmat
I've alloy rad ,MSD thermostat and switch and loom ..temps are all under control ..but in the next two weeks my forged engine goes in with a borg warner twin scroll and 2bar ..id rather stick things in place now ..ive got plug sleeves ..warpped the new exhaust down pipe and I think ill order a turbo blanket .
Old Sep 18, 2017 | 07:08 AM
cossynut2's Avatar
cossynut2
10 Year Member
There is no reason why your new forged engine, twin scroll BW and 2 bar of boost should suddenly give you over heating problems but if you feel you need for the turbo blanket etc go for it. Your car, your choice but personally I would get the new engine in and see how it runs first to determine if it needs extra cooling aids.
Old Sep 18, 2017 | 07:44 AM
StephTell's Avatar
StephTell
I have one on my turbo as it's situated directely underneath the fuelltank of my dragbike and it keeps everything surrounding the turbo a lot cooler and it doesn't smoke or smoulder but then again boost is applied in relative short bursts.
Old Sep 18, 2017 | 07:56 AM
Rsmat's Avatar
Rsmat
Thanks guys .
Old Sep 18, 2017 | 10:56 AM
cossynut2's Avatar
cossynut2
10 Year Member
Different situation in your case and a worthwhile and safe reason to fit one.
Old Sep 18, 2017 | 11:54 AM
nigel b's Avatar
nigel b
ceramic coating would be the way forward if you are worried about heat
i run 2 bar and mine sees track use and ive never needed one
Old Sep 18, 2017 | 12:23 PM
Rsmat's Avatar
Rsmat
I think I may send the turbo off for the rear housing to be ceramic coated instead .
Old Sep 24, 2017 | 02:12 PM
turbotrev's Avatar
turbotrev
Ive heard turbo blankets tend to make the exh housing more prone to cracking?
But I guess wether its ceramic coated or wrapped in a blanket they both do the same thing...
Ive heard warranties are void on some tubular exh manifolds when ceramic coated as again they tend to crack....
Cheers Paul
Old Sep 24, 2017 | 08:24 PM
stevieturbo
C**t
Anything that promotes heat retention within the metal will lead to premature cracking.
