help do identify rear cosworth arm
Old Sep 10, 2017 | 01:26 PM
florent78's Avatar
florent78
Default help do identify rear cosworth arm
hi guys
I started to work on my 2WD cosworth after being stopped a long time.
before stopping, I bought a full rear beam and arm and ship it directly to get the 6 degrees modification.
yesterday, starting mounting the parts I realized:
- I do not have the fixation axle for the rear Anti Roll Bar
- the width to fix the damper is larger than my original arm
2WD width : 42mm
this new arm: 52mm plus you can see the design is different
I've been able to install the 7'5 differential so the beam is a 2WD beam
any idea to identify the arm specification ?
thanks for your help.
I looked up for a kit to update the ARB with rose join link and bracket but I did not find anything
Attached Thumbnails help do identify rear cosworth arm-img_4139.jpg   help do identify rear cosworth arm-img_4132.jpg
Old Sep 10, 2017 | 01:54 PM
costina's Avatar
costina
Live long and prosper!!
This is a gen cosworth saff 89 arm.
If that helps.
Old Sep 10, 2017 | 02:12 PM
florent78's Avatar
florent78
Thanks
but i can see on the pic you have the axle for the arb fixation
its a 1989 2wd so
but i never see 2 different ref for the rear with wider fixation
Old Sep 10, 2017 | 08:01 PM
Marc sierra's Avatar
Marc sierra
Is the hole size for the bolt of the shock 10 mm? If so I suppose it's an arm off a standard non-cosworth Sierra.
Old Sep 11, 2017 | 08:03 AM
florent78's Avatar
florent78
Same diameter for the hole bolt
and i fitted the 2wd hub properly
really strange
regarding my old email
it seems to be a group a beam and arm
Old Sep 11, 2017 | 09:33 AM
Marc sierra
The wider mount for the shock is normally only on normal Sierra's. The bolt hole can have been drilled from 10 to 12 mm to fit the Cosworth shocks.
Old Sep 11, 2017 | 07:59 PM
florent78's Avatar
florent78
Thanks
so they have been drilled
appart of those 2 differences
cosworth arm are reinforced / stronger than the "normal" sierra arms ?
Old Sep 11, 2017 | 08:30 PM
james kiely's Avatar
james kiely
i used these whiteline universal balljoint drop links .although i havent tested it out yet.
ps i know theres a driveshaft bolt missing lol
Old Sep 12, 2017 | 12:56 PM
florent78's Avatar
florent78
Thanks
do you have a link for the whiteline drop links ?
thanks
Old Sep 12, 2017 | 01:45 PM
james kiely
http://www.demon-tweeks.co.uk/perfor...int-drop-links
Old Sep 12, 2017 | 03:25 PM
Marc sierra
I don't know if the actual arms are stronger. The bracket for the shock looks stronger on a cossie arm though.
