8 valve 2.0. dohc induction manifold
Old Sep 4, 2017 | 07:56 PM
geoff80's Avatar
geoff80
Default 8 valve 2.0. dohc induction manifold
The standard 8 valve inlet manifold stands very high over the rocker cover and I am wondering whether to save space the inlet manifold from a dohc 16 valve RS cylinder head (which appears much lower!) will fit the 8 valve head?? In more simple terms, can anyone advise me please whether or not the manifolds are interchangeable???? If they are I'll be looking for a 16 valve manifold.
Old Sep 5, 2017 | 08:49 PM
JFB Tech's Avatar
JFB Tech
Not entirely sane
Manifolds are very different as the 16 valve head has oval ports, 8 valve ports are almost square.
Old Sep 5, 2017 | 08:59 PM
geoff80's Avatar
geoff80
Default 8 valve 2.0 dohc induction manifold
Thank you very much for that clear and helpful answer. There is no hurry at present so it's back to the drawing board!
