no power/ignition.
Old Sep 2, 2017 | 04:14 PM
krolly's Avatar
krolly
Default no power/ignition.
as title really I have no power to the car at all. no interior lights/clock, ignition nothing. battery is good. have checked all fuses all ok. checked the relays the tall red relay smells a bit funky looked inside nothing burnt/scorched. could anyone point me in the right direction as it's doing my head in lol
Old Sep 2, 2017 | 07:12 PM
studabear's Avatar
studabear
How many cables are connected to the positive terminal of the battery?
Old Sep 2, 2017 | 07:28 PM
krolly's Avatar
krolly
think 4 off the top of my head mate. was fine this morning as took to the body shop to get booked in
Old Sep 2, 2017 | 07:31 PM
studabear's Avatar
studabear
Have a good luck at all the connections at the positive terminal as a starting point.
Old Sep 2, 2017 | 07:35 PM
krolly's Avatar
krolly
done that mate had all off checked the fitti vs on the cables checked the earthing too.
Old Sep 2, 2017 | 07:43 PM
krolly's Avatar
krolly
Old Sep 2, 2017 | 08:00 PM
james kiely's Avatar
james kiely
Igntion switch can often be the problem.have a look at the electrical side of the switch
Old Sep 2, 2017 | 08:10 PM
krolly's Avatar
krolly
hi would I check that mate. would that stop even the interior light and clock not working?
Old Sep 2, 2017 | 08:28 PM
studabear's Avatar
studabear
hazard lights work?
Old Sep 2, 2017 | 08:34 PM
krolly's Avatar
krolly
nothing mate literally I have no power to anything. I've had a meter over the battery and that's bang on plus it's o my 3 weeks old. I'm totally stumped
Old Sep 2, 2017 | 09:11 PM
james kiely
Try giving the wires at the back of the ignition a wiggle or tap the connection where the wires go into the connection.
I've had a similar prob on a 1600i and it presented the same
Old Sep 2, 2017 | 09:13 PM
krolly's Avatar
krolly
cheers mate I'll give that a try in the morning. if not be a cal to a auto electrician or just order a new loom as want it done asap for the retest on mot
Old Sep 2, 2017 | 09:28 PM
studabear's Avatar
studabear
The fact that it not got hazard lights which work or should work with ignition off tells me its not the ignition switch, I have seen a few fords over my 22 year in the motor trade with no electrics and its been a connection at the positive terminal of the battery.
Old Sep 3, 2017 | 11:19 AM
krolly's Avatar
krolly
problem solved!! spent an hour going over all cables connected to the positive side of the battery. found to crappy connections in one cable that had come loose beneath some shrink wrap. 're crimped the cables and shrink wrap and vrooom she's alive!! thanks for everyone's suggestions
Old Sep 3, 2017 | 03:09 PM
studabear's Avatar
studabear
Good result then.
Old Sep 3, 2017 | 03:14 PM
james kiely
Good spot studabear,that's one for the memory bank
Old Sep 3, 2017 | 07:12 PM
krolly's Avatar
krolly
defo mate since buying the car found so many bodges by the previous owner ita unreal. just hope they soon stop as apart from this one there cost me a fortune
Old Sep 4, 2017 | 04:45 PM
Karlos G's Avatar
Karlos G
Balls Deep!
Welcome to RST ownership! lol
Good call by Stu, had to be something battery end really as there was power to nothing at all.
Old Sep 4, 2017 | 07:56 PM
krolly's Avatar
krolly
haha! it's giving me a headache so far putting right what the last owner bolloxd up and bodged
