General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Hi all I have a S2 Escort Turbo I have heard that the Transit connect starter fits the Escort and has a bit more power. Could anyone advise if its a particulary year of Transit and whether the body is any slimmer than the RST one as I am having a slight clearance problem between the starter and the sump due to fitting a Ford KA gearbox ( starter is located lower down on the bell housing )
is the body slimmer on this one compared to the RS standard one ? I have fitted a KA box and the starter is fouling the sump I have modified the sump a little with a hammer to help it fit better. A slimmer starter will be clear of the sump
I have fitted the 1.3 KA box fro the duratec with front mounted starter just trying to source the hydraulic connection so I can pipe the slave cylinder up then need to put all the ancillaries on the engine
