New ecu wiring harness - sierra cosworth
Old Aug 29, 2017 | 02:07 AM
europatek's Avatar
europatek
Default New ecu wiring harness - sierra cosworth
Has anyone installed a new ECU wiring harness, the one available from Burton, and if so has there been a noticeable improvement in the running of the engine?
Old Aug 29, 2017 | 06:28 AM
The Crocodile Hunter's Avatar
You can never really go wrong replacing a 25 year old loom!
Also try searching for cw looms
Old Sep 4, 2017 | 05:40 PM
Guinnless's Avatar
Guinnless
I got mine from Motorsport Developments. It definitely more crisp in its response. Plus it's nice and safe with no bare or cruddy wiring. The fans run faster too! 😁
Old Sep 4, 2017 | 08:29 PM
Loomer's Avatar
Loomer
Lots of advantages if you know the Weber ecu well enough, and what it needs to operate at its best
Old Sep 4, 2017 | 09:26 PM
cossynut2's Avatar
cossynut2
10 Year Member
I had an intermittent misfire on my 2wd Saff and replaced the engine, fuel pump and fans looms which fixed the problem straight away. A 27 year old original Ford wiring loom will be getting worn out and can cause all sorts of problems.
Old Sep 6, 2017 | 03:54 PM
1374lee's Avatar
1374lee
James at Autodynamix, spot on customer service and for the quality of his looms.
Thanks. Lee.
Old Sep 6, 2017 | 04:50 PM
155lee's Avatar
155lee
Does anyone make 1 that looks like the original loom?
Old Sep 6, 2017 | 04:58 PM
Loomer's Avatar
Loomer
I've done a few in insulation tape for bufty cars.
Old Sep 6, 2017 | 05:13 PM
costina's Avatar
costina
Live long and prosper!!
Conduit and insulation tape......lol
Old Sep 7, 2017 | 05:19 AM
155lee's Avatar
155lee
Do You make the looms?
Old Sep 7, 2017 | 10:49 AM
Loomer's Avatar
Loomer
Might do
Old Sep 9, 2017 | 03:55 PM
costina's Avatar
costina
Best in the bussiness even i'd buy one and as u know i can make my own.
Old Sep 9, 2017 | 07:17 PM
Loomer's Avatar
Loomer
Old Sep 9, 2017 | 08:58 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Loomer autodynamix on here every time for a cossie loom. Not cheap but they are a very very nice bit of kit.
