cut/drill front bumper
Old Aug 26, 2017 | 09:31 PM
krolly's Avatar
krolly
Default cut/drill front bumper
Since moving my fm and rad more towards the bumper. I've noticed there's hardly any of the fmic not covered by the bumper. surely this can hardly lower the temps. for .ore air flow has anyone made subtle changes to create more air flow. I've thought about drilling a pattern in the bumper behind where the number plate goes so if I put the plate back on it still looks standard
Old Aug 27, 2017 | 06:41 AM
If you do that behind the number plate ,put the plate on ten mm spacers gives more air a gap to go through
Old Aug 27, 2017 | 09:41 AM
krolly's Avatar
krolly
I ment to relocate the plate on a temp basis then if I want to put back to look standard it would cover it ? didn't know if other people had anything different with out cutting the bumper
Old Aug 28, 2017 | 04:38 PM
mentalasanything's Avatar
mentalasanything
Out of interest how did you move the rad forwards?
I'd go with drilling circular holes behind the plate and remove/replace the plate as required. also, a lot of people remove the bottom bar on a '90 spec bumper.
Lee
Old Oct 20, 2017 | 10:07 AM
Karlos G's Avatar
Karlos G
Balls Deep!
You might find this thread useful mate if you trying to get the best setup for efficient cooling and airflow...
https://passionford.com/forum/ford-e...tallation.html
