What dry sump kit
Old Aug 21, 2017 | 07:33 PM
mattman1234's Avatar
mattman1234
Default What dry sump kit
As title really,any reccomendations,thoughts,do i need separate stage for turbo,or can this drain straight into the sump as standard ??.Looking at the turbo sport one,seems pretty reasonable price ?
Cheers all
Old Aug 22, 2017 | 06:21 AM
lacey's Avatar
lacey
You don't need a turbo scavenge stage unless
Your turbo position is very low in which case
Gravity draining from the turbo can be a issue
You can drain into the side of the pan
Or even near the scavenge tube on the dry sump
Pan
I do the opi dry sump kits
If you have a google at some pics or go
On Burton's site you will see the turbo drain in the
Side of the pan
Old Aug 22, 2017 | 06:28 PM
mattman1234
thanks,,will have a look
Old Aug 22, 2017 | 08:40 PM
mk2cossy's Avatar
mk2cossy
Dan Lacey is your man
Old Aug 31, 2017 | 04:41 PM
mattman1234
Does anyone have an opi dry sump kit on their setup ?,if so, could do with a measurent from the centre of the crank pully,to the furthest outer edge of the pump.
Cheers all
Old Sep 1, 2017 | 10:04 AM
lacey's Avatar
lacey
If you add 125mm on the power steering pump mount face on the block
Then that probably a little more then you need
lacey's Avatar
lacey
It's probably nearer 105 mm than 125 mm
Old Sep 1, 2017 | 10:15 AM
mattman1234
top man
Old Jan 28, 2018 | 01:01 PM
mattman1234
I'm gonna be ordering my dry sump kit soon,opi,or turbosport,
The opi sump looks a bit bulky to me,but let to believe its a better type of pump,
decisions,decisions
Old Jan 29, 2018 | 04:20 AM
mattman1234
Can the existing piston jet spraybar be re-used ?
Old Feb 14, 2018 | 05:32 PM
mattman1234
Think this is the only place for the tank
Old Feb 14, 2018 | 07:18 PM
mattman1234
I'm going to order some braided pipe / fittings to check routes and bends,I don't want to skimp on quality ,therefore speedflow "an" fittings are on the list.Are these the best quality,i'm judging on price here.
Old Feb 15, 2018 | 06:32 PM
mattman1234
pressure relief valve turned up,certanly sterdy !
Old Feb 15, 2018 | 06:47 PM
Caddyshack's Avatar
Caddyshack
Looks great, I would zircotec coat the down pipe and remove that wrap, you have such a nice instal I think it would benefit from the neatness and better heat management.
Old Feb 15, 2018 | 07:19 PM
mattman1234
Thanks,,a new exhaust is on the list of things to do first,have looked into the coating before,but ŁŁŁŁ ,its on the limit for track days
Old Feb 19, 2018 | 07:34 PM
mattman1234
Took of the sump tonight ,to try and figure out a way of re-routing the spray jets with a dry sump pan.
Look what i spotted
see if anyone can see it:-
Old Feb 19, 2018 | 07:39 PM
Caddyshack's Avatar
Caddyshack
Arp nuts or what is written under the piston?
Old Feb 19, 2018 | 07:50 PM
mattman1234
Old Feb 19, 2018 | 07:53 PM
Caddyshack's Avatar
Caddyshack
Side plug funny angle, is that supposed to be a blank?
Old Feb 19, 2018 | 07:54 PM
mattman1234
yep,looks like its pushed out
Old Feb 19, 2018 | 07:58 PM
Caddyshack's Avatar
Caddyshack
Is that a an over pressure type thing? Can't think why it would be there unless for assembly but then you would think it would have a retaining system?
Lucky save though eh?
Old Feb 19, 2018 | 08:10 PM
Adam-M's Avatar
Adam-M
Caught just in time by looks of it, are you running 4x4 running gear? Just wondering as I see a sump gasket and didn’t think you fitted them in 4x4 format.
Old Feb 19, 2018 | 10:47 PM
Mad_Mat's Avatar
Mad_Mat
New Owner
Wow that is lucky. I wouldn't expect that with a Cosworth pump either.
Was your oil pressure still good?
Old Feb 20, 2018 | 07:22 AM
nixon_2wd's Avatar
nixon_2wd
Wow good thing you decided to go dry sump and caught it!
I believe thats the pressure spring retaining cap for the spray bar.
Old Feb 20, 2018 | 04:55 PM
mattman1234
yeah,,was a lucky save,maybe they needed to use a harder punch
Old Feb 23, 2018 | 07:19 PM
mattman1234
sump pan arrived today
Old Feb 23, 2018 | 07:33 PM
mattman1234
Its a 2wd setup
Old Feb 25, 2018 | 01:24 PM
mattman1234
Anyone have a 4x4 oil pickup pipe they want to move on
Old Feb 25, 2018 | 07:12 PM
mattman1234
Made a flange today,will either tap this for a banjo,or weld a the pipe straight into it.
Just poked that pipe in to check it lines up with the hole
Old Mar 22, 2018 | 09:08 PM
mattman1234
Old Mar 22, 2018 | 09:38 PM
Adam-M's Avatar
Adam-M
At main cap #3 is that two pieces of pipe pushed together? I wouldn’t run it the way it is but would make a good template to get one fabricated.
Old Mar 23, 2018 | 05:20 AM
mattman1234
no, its solid underneath,its not a join,its the origional 4x4 pipes ,the larger pipe is just sleeve over the top to make it rigid
Old Mar 23, 2018 | 09:01 AM
nixon_2wd's Avatar
nixon_2wd
Looks cool. Good mod. How did you incorporate the pressure spring etc.? I would consider maybe doing an oil change on that engine of yours
Old Mar 23, 2018 | 04:41 PM
mattman1234
the spring is external,using this(slightly over the top),adjustable check valve.
gonna givethe spray bar, bit of a file,some paint and will look factory
Old Mar 23, 2018 | 04:45 PM
mattman1234
This is what is underneath,ive brazed over the existing pipes.
Part of the pickup pipe is a spine that runs down the back,the sleeve is where the spine finishes
Old Apr 2, 2018 | 04:30 PM
mattman1234
Finally happy with it
Old Apr 2, 2018 | 04:59 PM
Caddyshack's Avatar
Caddyshack
That crank might need a polish...lol
Old Apr 27, 2018 | 07:08 AM
mattman1234
All belts sorted now,now starting tank install and pipework
Old Apr 28, 2018 | 07:48 PM
mattman1234
Thinking of putting a std type filter before and after the pump,any thoughts ,will it affect pressure much,i'm thinking not.The one after is a deffo
The reason i want before is that i'm getting the tank welded with extra unions.Just a bit worried about any swarf,as is a solid tank.
Old Apr 28, 2018 | 07:50 PM
mattman1234
