Sierra Rs Cosworth Bumper Sliding Bracket dims
Hi All
Could anyone be so kind as to supply me with the dimensions of the square tube or box section of the aftermarket slide brackets. The part where it gets bolted to the front quarter side panels. I want to replace the plastic with steel ones I want to make myself?
Also does anyone find the bumper better to be mounted (bolted in) this way or is the plastic brackets(the parts where they slide, clip and lock together) better?
Hi All
