did you come right with this mod / install? I also have a windy sunroof and motor kit and would also like to know if there are other solutions in case I run into same problem.
There just one question from your pic I would like to know, what is that plastic flappy bit sticking out on the backend of cover? Seems like that you have a plastic bracket attached?
For the sunroof cover do you have the steel bracket and correct motor etc?
Headlinings are different between manual and electric. You will need to make bracket to hold the rear section as the roof skin on the later cars are different too....
