Alternator.
Old Jun 22, 2017 | 09:14 AM
Keith Shepherd's Avatar
Keith Shepherd
Default Alternator.
Hi all,
i have a 2005 st 170 and the battery light flickers on when driving. I have changed the battery as the test came back low but the light still flickers. I have had the alternator tested and came back as 13.88 to 14.00 is this right?
any help would be greatful.
keith.
Old Jun 22, 2017 | 12:12 PM
Rowe's Avatar
Rowe
Skint
doesn't sound excessively low to be perfectly honest.
are you suffering from battery drain at all? if no, I'd be inclined to leave it if you can put up with the light coming on every so often
Old Jun 22, 2017 | 12:25 PM
martysmartie's Avatar
martysmartie
Common issue with "Smart charge" and nothing unique to your model.
The usual problem is a loose connection on the 3 pin plug on the alternator.
Did you get a silver calcium battery?
Martin
