Changing turbo?
Old Apr 11, 2005 | 09:36 AM
Andy f's Avatar
Andy f
Default Changing turbo?
Im thinking of replacing the turbo on my 4x4 sapphire and was wondering if its something I could do myself. Is it a big job and what problems might I find.
Old Apr 11, 2005 | 09:52 AM
cossied's Avatar
cossied
Default turbo
Took mine off yesterday takes about 1 hour. remove heat shield take off hoses,water pipes and oil feed, undo exhaust and remove the studs on the outside to allow the exhaust to be move away. undo the oil drain pipe, undo the four 17mm nuts that hold the turbo to the manifold and it is off regards ED
Old Apr 11, 2005 | 10:24 AM
Andy f's Avatar
Andy f
Thanks for that, when replacing the turbo is there any parts needed i.e gaskets nuts etc.
Old Apr 11, 2005 | 11:38 AM
cossied's Avatar
cossied
Default turbo
there is a gasket on the oil return pipe and 4 washers on the water feeds. there are no gaskets between turbo and manifold or tubo/exhaust regards ED
Old Apr 14, 2005 | 07:24 PM
Niall.b's Avatar
Niall.b
Pretty straightforward if you are just replacing. changing type is a different matter as u will need access to fabrication kit etc to make exhausts & pipes etc line up
Old Apr 14, 2005 | 10:59 PM
richm's Avatar
richm
Default Re: turbo
that's a very "Haynes Manually" simple explanation Ed
You got some wierd spanners, or are you a part time gaenocologist?? D
seriously, a couple of them are a tw@t to get to, a more detailed insight into how you did them would be very helpful!!
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
siscossie
Aug 27, 2015 09:27 PM
cameron2
Aug 25, 2015 07:18 AM
Dicko&Vacant
Ford Focus RS Parts for Sale.
Aug 23, 2015 03:11 PM
