Sierra steering bush conversion
Old Jun 10, 2017 | 10:15 PM
dave99's Avatar
dave99
Default Sierra steering bush conversion
Hi, has anyone here converted their sierra from bush to bearing on their steering Column?
My stearing column has a lot of play at the bulkhead and I've heard there is a bearing conversion.....
Thanks, dave
Old Jun 10, 2017 | 10:28 PM
big_wasa's Avatar
big_wasa
It was a common mod for kitcars with Sierra running gear. Have search for Locost lower steering column bearing.
You keep the sleeve that fits on the column and turn it down or sand it down so it fits in to a 25mm self centring bearing.
They come with several mounting options.
Old Jun 11, 2017 | 06:50 AM
A few lads on here have done the conversion.
Old Jun 11, 2017 | 07:48 AM
cozzy jeff's Avatar
cozzy jeff
Thanks, dave
have a look through my resto thread,plenty of pics in there.
Old Jun 11, 2017 | 08:18 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
I did mine I don't have pictures and the cars locked away at the mo waiting an engine. But funny enough I was in Cromwell tools the other day and I see they sell the same bearings
Old Jun 11, 2017 | 09:42 AM
dave99's Avatar
dave99
Thanks for that��
Took me a while to find It!
That is a serious Rebuild! Lovely car....
Do you have a number for the bearing and Housing? I might be able to source it locally from an engineering supplier...
Cheers,
Dave
Old Jun 11, 2017 | 03:20 PM
tjRS500's Avatar
tjRS500
There for sale on eBay. That's were I got mines, less than Ł15 from
Memory
Old Jun 11, 2017 | 05:08 PM
cozzy jeff's Avatar
cozzy jeff
Thanks for that��
Cheers,
Dave
heres one,im sure mine was half the price of this one but itll give you an idea of what you need.
http://www.ebay.co.uk/itm/Ford-Escor...sAAOSw32lY0Wwc
Old Jun 11, 2017 | 06:05 PM
Adam-M's Avatar
Adam-M
I found it best to make a template up
Trial fitted it from the outside
Before putting my back out and lying upside down on the drivers seat to fit it on the inside
Old Jun 11, 2017 | 06:11 PM
Adam-M's Avatar
Adam-M
I also made this alloy bush to replace my original perished rubber one, steering is brilliant very responsive and actually isn't to harsh either
Old Jun 11, 2017 | 06:19 PM
cozzy jeff's Avatar
cozzy jeff
think i would have went for an aluminium bush if they were available at the time of doing mine
Old Jun 11, 2017 | 06:34 PM
dave99's Avatar
dave99
Thanks lads,
I might make up an alloy bush while I'm at It!
Dave
Old Jun 11, 2017 | 07:51 PM
tosh's Avatar
tosh
I got mine from James
https://www.autodynamix.co.uk/websho...orth-yb-parts/
Old Jun 12, 2017 | 09:30 PM
dave99's Avatar
dave99
I have one problem, the diameter of the plastic insert is 23.6mm in places.....
I'll need a new one even if I upgrade to the bearing.....
Dave
Old Jun 13, 2017 | 03:42 PM
1374lee's Avatar
1374lee
Default protect
Originally Posted by tosh
Me to,not fitted yet though.
Thanks. Lee.
Old Jun 17, 2017 | 06:43 PM
Jack and the Beanstalk's Avatar
Hi All
My question can you still adjust the steering once the bearing is installed?
I have a bearing replacement too for my sapph but not sure to install if I loose adjustablity?
is it better to put on inside or outside of firewall / bulkhead?
Old Jun 18, 2017 | 10:12 AM
Adam-M's Avatar
Adam-M
In what way do you want to adjust yours? It doesn't change anything that the original plastic bush did apart from support the shaft better.
I put mine on the inside to protect it from the elements but it is a cunt to fit/change.
Old Jun 19, 2017 | 06:32 AM
Hi Adam
I'm referring to the adjustable steering column and wheel. So will I still be able to tilt and trim the complete assembly once seated?
Old Jun 19, 2017 | 09:59 AM
grcossie's Avatar
grcossie
The adjustment will still work, as it sits higer up then the bearing
Old Jun 19, 2017 | 10:51 AM
Adam-M's Avatar
Adam-M
Yes that hasn't been affected.
Old Jun 19, 2017 | 01:31 PM
fatboy billy's Avatar
fatboy billy
This something I want to do to mine to stiffen the column up bit keep putting it off as it looks like a ballache to fit lol
Old Jun 27, 2017 | 10:19 PM
dave99's Avatar
dave99
I've done a complete u turn on this and bought a new old stock 4 piece kit.
I figured that the original has lasted over 30 years so this one should outlast Me!
Thanks for all your comments....
Dave
