t p s readings
Old Jun 8, 2017 | 09:44 PM
ray barker's Avatar
ray barker
Default t p s readings
ive seem to have lost nearly 2000 rpm. i cant get my stg1 saff to rev past 45000rpm its a process of ilimination im nearly there i thinks. i checked the tps readings with multi metre and throttle plate shut its reading 4.81volts. and wide open its 0.44. shouldnt this be the other way arround. would this be because its got 4wd tps with the outer wires swoped arround fitted to it. i measured this of pins 1&17 pin of the ecu plug mine is a 2wd by the way. ive not taken the throttle body of yet for a closser look just thought id run it past every body here . i think the propper readings are 0.35 volts clossed and just under 5 volts open. if my readings i have now would this cause me running probs. thanks
Old Jun 9, 2017 | 06:46 AM
oldford's Avatar
oldford
Assuming you're using a 2wd ecu:
The TPS should NOT be the other way around. On a 2wd 5 volt is closed.
If you're using a PF09 TPS from a 4wd you will not get exactly 5 volt at throttle closed.
The throttle signal is not causing your running problems.
Old Jun 9, 2017 | 10:57 AM
ray barker's Avatar
ray barker
Thanks m8 i looked in the archives it must have been a 4wd post shut mine is 4.81 being its at 0.44 wide open is this giving me full throttle shouldnt it be 0.35 thanks
Old Jun 9, 2017 | 11:05 AM
oldford's Avatar
oldford
Yes, the signal is low enough to give you WOT enrichment.
Whether or not the throttle fully opens, I cannot see that from here.
The signal is suggesting it's wide open.
Old Jun 9, 2017 | 05:22 PM
Loomer's Avatar
Loomer
Be careful with it, i would be monitoring AFR and pulling data from the ecu before doing much more incase you end up loosing the engine.
Old Jun 9, 2017 | 08:08 PM
ray barker's Avatar
ray barker
my thoughts to ive set the tps now so when its wide open its going to 0.35 v now it was 0.44 whether its enough to make a difference. if this aint it im guna try a ignition amp after that its of for a setup some where i live in west cornwall any recomendations
Old Jun 10, 2017 | 01:03 PM
martysmartie's Avatar
martysmartie
As said assuming you have the standard ECU (L6) it will never work correctly with PF09 (i.e. 4x4 TPS) although it wouldn't cause this issue. It causes issue with the idle strategies as they are not open circuit at closed throttle like the PF01, as they do not contain a switch.
Martin
Old Jun 11, 2017 | 07:10 PM
ray barker's Avatar
ray barker
ive shafted the the throttle body now by school boy error. got another on the way i got to wait a week now dowww!!!!
