i am currently building a jago jeep running a 1600 pinto..i purchased engine which had previously been running with electric cooling fan..I now want to fit original cooling fan but the pulley on water pump has a large nut on front face which wont budge (nut is larger than centre hole on fan) ..Can someone advise if nut comes off,or do i need a different water pump....????
