Has anyone done the 2wd front cossie brake conversion on their RST and used the standard s2 alloys.
I put the brakes on yesterday but looks like I'm needing to grind the back face of the alloy and maybe even the caliper to get the wheel to clear also using a wheel spacer.
Not sure on 2wd. I managed to use 4wd caliper with 2wd discs, they went straight on no bother
