2L zetec turbo build
Old May 11, 2017 | 01:11 PM
Escortrs1986's Avatar
Escortrs1986
Default 2L zetec turbo build
Hi i was wondering if there's anyone out there that can shed some light on helping me find out the compression ratio for my zetec im building .
Its a 2 litre black top bottom end with st170 pistons and rods and Ill be using the black top head .
ive been told to use a 1.2mm focus rs mls but then ive read online that i should use a 1.8mm headgasket to lower the cr to 8.9.1.
Old May 11, 2017 | 02:21 PM
colins2's Avatar
colins2
i think it would have to be the 1.8mm gasket its the head cc on the ST170 thats makes the CR high.
Old May 11, 2017 | 06:20 PM
big_wasa's Avatar
big_wasa
The 1.8mm is the tried and tested route. It ain't cheap. You may get away with a thinner cheaper gasket and higher cr depending on what power your aiming for and mapping.
It's not a case of right of wrong but only what works.
