Thermostat coolant leak and other issues! ( ST170 )
Old Apr 25, 2017 | 11:52 AM
DJ_AL's Avatar
DJ_AL
Default Thermostat coolant leak and other issues! ( ST170 )
So after a month of hunting (the previous coolant was so diluted it was indistinguishable amongst​ the oil!) I found the coolant leak. I believe this is the thermostat housing. I was going to replace the o ring but this looks a little more terminal to me at a glance, thoughts?
Also, i discovered an odd burning smell this week and found the 2 plastic clips holding the front most hoses to the lip of the engine bay (adjacent to the top grill) had broken and the hoses dropped, the drivers side of which (one with some heat shielding sleave) had melted through almost breaking, pic below. Which part is this please, as it will need replacing 😞
Thanks in advance.
Allan
Old Apr 25, 2017 | 12:00 PM
Rowe's Avatar
Rowe
Skint
only way to make a good assestment on the condition of the housing is to remove it really.
It's only a few pins and you wont lose that much coolant by removing it. Mine has been replaced a number of times by the previous owner with none genuine parts, and since me purcahisng it i've had to replace it once.
I've only done 2 trackdays since this and maybe 700 miles on the road. No issues at the moment.
Old Apr 25, 2017 | 12:26 PM
DJ_AL's Avatar
DJ_AL
Thanks Rowe. She's going in for her cambelt change next week so i'll have them take a look and add it to the ever growing list of jobs to do. My Clutch Master cylinder started leaking the other week too, not a good month so i'm hoping to fix as much as I can myself.
