Sapphire wet boot carpet
Old Apr 1, 2017 | 08:15 PM
essy's Avatar
essy
Default Sapphire wet boot carpet
This is driving me mad, the boot seal looks good and the rear lamp cluster seals are good but there's water coming in from somewhere, can anyone suggest were else its coming from.
Old Apr 1, 2017 | 10:07 PM
Sierrasideways's Avatar
Sierrasideways
Holes under sunroof drain pipes at both corners of the boot may be blocked.
Philip.
Old Apr 1, 2017 | 10:12 PM
cossynut2's Avatar
cossynut2
10 Year Member
As above its a case of eliminating potential leak points. After checking the sun roof the next thing I would do is put dry newspaper or cardboard inside the boot and with it closed use a hose to spray water on the top of the bootlid only. Let the water run off and open the boot to check if there is wet inside. If there is none close it again and now spray water at the rear lights. Check it again.If the paper is still dry then it eliminates boot seal and light seals. Next potential leak point could be if you have any boot bottom grommets missing or not pushed in properly it will allow water to get inside the boot from underneath.Good luck.
Old Apr 3, 2017 | 06:10 PM
steppy's Avatar
steppy
Get in the boot with a torch and get someone to run a hose over to see if you can see anything
Old Apr 3, 2017 | 07:26 PM
Paul_RS's Avatar
Paul_RS
The seal may look good, but not seal. I had to pull mine up slightly to get it to be watertight.
Old Apr 3, 2017 | 08:20 PM
mechanic28's Avatar
mechanic28
what the above says, take all the carpet and trims out , put rear seats down get in nice and comfy get someone to spray the boot with water
Old Apr 5, 2017 | 10:01 AM
turbotrev's Avatar
turbotrev
Check the inside of the back panel where it meets the corners of the rear quarters, can sometimes leak from the seam of where those panels join on the body (and at a first glance can look like its the light seals)
Cheers Paul
Old Apr 12, 2017 | 07:04 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Cheers Paul
I had exactly the same problem and I found it to be what Trev has said. No leaks since luckily
Old Apr 12, 2017 | 08:00 PM
Sierrasideways
Essy are you still locked in the boot?
